1. Eric4Yeshua1337
    Eric4Yeshua1337 Light Load Member
    100
    206
    Apr 21, 2020
    Hello,
    Are there ways to make electronic connections to day cabs that don’t even have a radio? I would like to eventually get a good trucking GPS, cellphone charger going, or even some music.
    Thanks
    tscottme Thanks this.
  3. REO6205
    REO6205 Road Train Member
    13,168
    60,500
    Feb 15, 2014
    California.
    Check with your company before you start hooking up any radios etc. Whatever you do, don't start hooking up stuff on your own unless they tell you it's alright. Every mechanic I know has a whole long list of horror stories about drivers who install electrical stuff..
    Eric4Yeshua1337 Thanks this.
  4. Chinatown
    Chinatown Road Train Member
    77,753
    184,590
    Aug 28, 2011
    Henderson, NV & Orient
    Ask someone in the shop.
  5. tscottme
    tscottme Road Train Member
    You can use a bluetooth speaker that you bring or leave in the truck. You will likely want at least a 20 watt, if not 40 watt speaker. When BT speaker specs indicate how many watts of power they "blast", each speaker is only half of the listed total at full volume. You can use a BT earpiece or headset that connects to your phone also, although wearing a headset or earpiece all day will not be very comfortable. You cannot legally cover both ears while driving. There are bone conduction headsets that are also very effective. I think the brand is AfterShokz. It doesn't block your ear but you can hear your music/podcasts/phone calls just fine.
    Munch75 and Eric4Yeshua1337 Thank this.
  6. tscottme
    My trucking GPS WOULD NOT connect to the truck radio. The built-in bluetooth was ONLY for an add-on ELD setup. I had a Rand McNally RM740. Most or all of the tablet-based truck GPSes that do everything will likely connect to anything with BT.
  7. GreenPete359
    GreenPete359 Road Train Member
    2,252
    5,423
    Oct 21, 2017
    Driving my recliner
    Can they even order a truck without a radio & a cigarette lighter these days? I kind of figured these things would be standard equipment anymore.
  8. 07shaker
    07shaker Light Load Member
    200
    727
    Jan 12, 2013
    Tx
    I use the aftershokz headset every day in the office but it’s not very good for in a vehicle unless you’re ok with wearing earplugs. I find that even driving a car there’s enough road noise that I normally try to plug at least one ear and this is with the volume all the way up. So unless they have come up with a newer model specifically for trucking I wouldn’t recommend them for that application. For my work in an office dispatching I love them.
  9. Munch75
    Munch75 Light Load Member
    202
    437
    Aug 29, 2021
    Respectfully disagree... I love my aftershokz. Wear mine daily and love the fact that I know I can hear traffic and movement around me and still hear my conversation or music easily. May ask if your positioning of the "speakers" are close enough to where they should be as I have tend to have to turn my volume down. It's also the first bluetooth mic that my significant other hasn't complained about picking up birds a mile away and not my voice like so many other devices we have tried. The mic does a great job cancelling out the in cab noise for the receiving caller. And if positioned where it should be, will be more than enough to hear without blaring. Now. If you are already hard of hearing, then you already picked the wrong device.
    You can listen to music plenty through them but go thinking you are going to get bass out of it that most people look for. The bass is limited to the vibration imparted to you and not movement of air via a speaker.
  10. tscottme
    I don't know about ordering options on a truck. I alwa drove OTR trucks so they had radios and other creature comforts.
  11. ducnut
    ducnut Road Train Member
    2,683
    8,131
    Dec 31, 2010
    SPI
    Are you saying there’s absolutely no 12V hookup of any kind?
