Battery voltage 2013 Freightliner Cascadia
Discussion in 'Ask An Owner Operator' started by Eric5220, Jan 7, 2025.
  1. Eric5220
    Eric5220 Light Load Member
    72
    25
    Mar 23, 2021
    I got a 2013 freightliner Cascadia dd13.im trying to get find out the avg voltage on truck. I’m scared because my battery light came on 2 days ago and it was because a small wire on the alternator broke off. I fixed it. When I’m driving it’s showing on dash 13.1 to 13.4 when parked up running 13.4-13.5 is the readings when driving are low or it’s normal ?
  3. 50WT
    50WT Road Train Member
    2,925
    26,776
    Dec 26, 2015
    Sounds normal to me.
    Bean Jr. and Eric5220 Thank this.
  4. Ridgeline
    22,718
    122,941
    Check it at the batteries, not the dash gauge.
    Lonesome Thanks this.
  5. 77fib77
    77fib77 Road Train Member
    11,609
    76,427
    Jul 7, 2010
    St Louis
    It's ok. 13.8 14.0 is best.
    Eric5220 Thanks this.
  6. Eric5220
    72
    25
    Mar 23, 2021
    Truck on or off ?
  7. AModelCat
    164,290
    Fully charged 12 volt battery will show 12.6 volts roughly. In order for a battery to maintain its voltage it needs to be fed with a higher voltage than 12.6 volts. 13.5 to 14 volts at the battery and output stud of the alternator is pretty typical. If you get up to the 15 volt range you'll start cooking batteries.
  8. Ridgeline
    22,718
    122,941
    running
  9. snowwy
    snowwy Road Train Member
    20,611
    13,326
    Jul 6, 2009
    At 13.5 it might be showing weakness. Usual is about 14.
    Measure the batteries with all accessories running. If you can run headlights, heater, wipers and whatever else. And maintain 13.5. You'll probably be ok. If it's lower. The alternator is getting weak.
    13.1 - 13.4 though is a sign right there. If you can find anyone that knows how to load test an alternator. They'll probably find it's going. But there's a possibility the batteries might be causing the alternator to show bad.
    77fib77 Thanks this.
  10. Dino soar
    Dino soar Road Train Member
    4,813
    27,058
    Dec 8, 2017
    That is the way to tell if your alternator is charging correctly, by checking it with all of your accessories running.
    snowwy Thanks this.
  11. Eric5220
    72
    25
    Mar 23, 2021
    with everything running is 13.1 13.3
