Battery's going dead
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dwight Goertzen, Feb 17, 2025.
  1. Dwight Goertzen
    Dwight Goertzen Bobtail Member
    28
    16
    Jan 2, 2024
    Hello i have a 2007 386. I've got something drawing on my batteries very slowly. Whenever I don't drive for a few weeks(usually in the winter) the batteries will be completely dead. Last time it happened they froze so I put brand new batteries in. I've had it in the shop now for awhile and one day I noticed the batteries were completely dead again. It took about three weeks on the brand new batteries to be completely dead. Any ideas where to start or some things to check?
    austinmike Thanks this.
  3. AModelCat
    163,950
    Unhook your battery cable, the negative one to the frame should work, and connect in a multimeter set to measure amperage between the cable and the ground stud of the frame. See how many amps are being drawn with the key off. You should leave it connected a minute or 2 to allow it to settle out. Anything over half an amp draw I'd say you've got an issue. In all honesty you really should install a battery disconnect or unhook the ground cable if you plan on leaving the truck sit for more than a week IMO.
    ducnut, Fieldrat and austinmike Thank this.
  4. Dwight Goertzen
    28
    16
    Jan 2, 2024
    Ok I'll give that a try! Yeah I'm thinking I might just put a disconnect on since it sits a lot in the winter. But I do wanna see if I can figure out what's drawing. Thanks!
  5. ducnut
    ducnut Road Train Member
    2,680
    8,097
    Dec 31, 2010
    SPI
    Key off, you can pull all your fuses and check the draw of every circuit. You simply touch from blade clip to blade clip. That’ll narrow down what is pulling juice.
