Beam Hauling - Flat Deck
Discussion in 'Heavy Haul Trucking Forum' started by GOV'T_Trucker, Jan 28, 2017.
  1. GOV'T_Trucker
    GOV'T_Trucker Heavy Load Member
    782
    668
    May 28, 2011
    I was watching some youtube videos and came across these 2 videos on this guys channel... I will have to say I have never seen a bridge beam hauled with a deck-plate and flatbed trailer.. Only every seen deck-plates and dolly's... This isn't normal in Canada, what about the US?
    This Father and Son team seems very professional.. Just starting watching their channel..
  3. Ruthless
    Ruthless Road Train Member
    9,134
    90,644
    Aug 28, 2010
    The City.
    @PeteyFixAll didnt you show me a pic similar to the flatbed and wheel plate couple weeks ago- with an out of service accompaniment?
  4. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    Have seen pictures off long poles being hauled the same way.
    rank and PeteyFixAll Thank this.
  5. johndeere4020
    8,522
    119,295
    Jan 1, 2010
    A long pole with a high flat under the back of it?
    rank, snowman_w900 and PeteyFixAll Thank this.
  6. PeteyFixAll
    PeteyFixAll Medium Load Member
    373
    8,071
    Oct 26, 2015
    I haven't seen one out of service??
    But depends on the state, some recognize this some don't!!!
    I haven't done it but know a few guys that do it with transmission poles.
    They run a 48' flat with log bunks on it, then put a log bunk with a king pin in the 5th wheel plate, chain it all together, hang some air lines and you got a 120' trailer!!! Or something between 48' and ????
    They do sometimes need to educate the cop and explain that the permit says they can!!!
  7. Ruthless
    9,134
    90,644
    Aug 28, 2010
    The City.
    I'm fairly certain I've seen a pic lately of it- nose of the trailer was dangling pretty low off the bottom of the load...
  8. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    Not a but several in one load.
    Saw that on Hanks truck forum.
    Think it was taken in Utah or Nevada.
    rank Thanks this.
  9. TripleSix
    133,034
    Second video, when starting out, the first right turn is a Wrong Way...notice what the front car does?
    Nice video, BTW. Beautiful 4axle W9
  10. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    Like this?
    PeteyFixAll and not4hire Thank this.
  11. Oxbow
    Oxbow Road Train Member
    13,593
    140,815
    Nov 24, 2015
    In the 80s I worked for a bridge building contractor, and hauled many pre-stressed concrete bridge beams this way. These beams are poured with cables running through them that have tension pulling down. After the concrete has cured the tension is released, which gives the beam camber. Because of this they can only be hauled by supporting the ends of the beam. If for example a beam was put on uneven ground where the weight of the beam was supported in the middle, it would break the beam.
    I have not hauled these for many years and am not aware of current permit requirements. There are steerable and non steerable dollies made specifically for this purpose, but a flatbed and fifth wheel bolster work as well if one can get by with non steerable.
    @cnsper has alot of experience hauling bridge beams in Eastern Washington, Northern Idaho, and Montana; perhaps he will chime in.
