Beartracker 885
Discussion in 'CB Radio Forum' started by joey7119, Jan 22, 2026.
  1. joey7119
    joey7119 Light Load Member
    85
    37
    May 30, 2008
    baltimore, maryland
    Hello can someone tell me what antennas work best with this cb Beartracker 885. Hooking it up in my KWT660. thanks
  3. Ridgeline
    22,723
    123,063
    I have a few here I ordered but haven't tested for my trucks. I heard from one person that he has been working flawless and he loves it.
    Let's start with this question - is this your truck or is it a company truck?
    Why I ask is if you need to modify your truck, it is better to be yours and not theirs.
    Chances are that the antenna system on the truck is multiplexed with the am/fm radio and performs as well as or worse than if you would just hook up a piece of pasta to the coax.
    This is a roundabout way to answer your question, seeing that the best solution is to start with a direct coax, leaving the rest of the system intact, and using a good mount with any antenna that you can afford.
    So if this is your truck, get a quality coax from a good source (DX engineering) and a good mount (I bought them in bulk, so I don't have a recommendation - another forum member can recommend one).
    Once this is done, then it is a matter of checking the system to find out if you need bonding to make the system effective or if it is good enough for you. Most likely, you will need bonding.
    joey7119 Thanks this.
  4. Tonythetruckerdude
    Tonythetruckerdude Crusty Deer Slayer
    2,909
    54,037
    Dec 8, 2012
    hunting...../ retired
    I’ve had luck with audio king
