best antenna is ?
Discussion in 'CB Radio Forum' started by 2hellandback, Jul 31, 2013.
  1. 2hellandback
    2hellandback Heavy Load Member
    978
    237
    Dec 19, 2007
    Blackfoot Idaho
    OOPs ! Sorry about that !
  3. handlebar
    handlebar Heavy Load Member
    A half-mile longwire susupended by a kite, with an antenna matcnbox that will handle very very high voltages, and an array of dragging ground straps on the ground, liberally soaked with salt water.
    (well, you asked....)
    RedForeman Thanks this.
  4. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    wire coat hangers work really well...least better than the plastic coat hangers....
  5. tribute2dad70
    tribute2dad70 Bobtail Member
    7
    Aug 6, 2013
    Wilson 1000 or wilson 5000 if your running a box, if not a wilson 500 . They come already tuned with vary low swr's. I've got a 1000 I run my cobra 29LTD, Texas Star 250HDV and I can talk up to 100 miles if the airways arent crowded.
  6. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Get a Predator 10K, and when skips rolling, you should be able to talk 1000's of miles with that TS-250...
  7. poppapump1332
    poppapump1332 Road Train Member
    2,986
    2,464
    Jan 2, 2010
    birdsboro,pa
    Best antenna is a 102 steel whip hands down which is not practical in a truck so is a davemade the best predator 10 is is good I prefer monkey made.wilsons are way overrated just look at the keydowns comps nobody uses wilsons!
  8. Turbo-T
    Turbo-T Road Train Member
    1,953
    708
    May 31, 2009
    That's probably because Wilson's won't handle the amount of power the key down competition is running.
  9. tribute2dad70
    7
    Aug 6, 2013
    Well for a person that just wants to get out good and is not wanting to spend alot of money, a Wilson is a good antenna. Ive used them for some time now and never had any problems. You can spend the money you earn and get a monkey made, 1000 watt linear and key up on everyone but you have to ask yourself if its really worth it but im sure most just want something reliable that wont be expensive and can handle a little power. Just sayin
  10. snoracerx
    snoracerx Light Load Member
    57
    31
    Mar 18, 2012
    Wisconsin
    Nothing tougher than a Wilson they also work really well for most radio setups
  11. Gold_Miner
    Gold_Miner Medium Load Member
    496
    227
    Nov 4, 2011
    Burnet, TX
    How about if you are in a Freightliner Cascadia and want to use the dual antena mounts on the side of sleeper, what works best for that?
