Best solution for strapping
Discussion in 'Questions From New Drivers' started by sjohnson1097, Nov 22, 2023.
After unloading cargo and need to wrap up the nylon strapping, what most applies to you:
  1. I wrap the strapping by hand and is not a problem
    5 vote(s)
    25.0%
  2. I wrap the strapping by hand and wish there was an easier/ faster way to do this
    1 vote(s)
    5.0%
  3. I use a strap winder but doesn’t seem to work well
    0 vote(s)
    0.0%
  4. I use a strap winder and it works well
    13 vote(s)
    65.0%
  5. I have an automated system or machinery built in to assist in the winding and storage of straps
    1 vote(s)
    5.0%
  1. sjohnson1097
    sjohnson1097 Bobtail Member
    Hi, I am curious about what to do with strapping and if wrapping them by hand is the easiest or if there are better ways. Do people use winders?
  3. Chinatown
    Chinatown Road Train Member
    77,612
    183,580
    Aug 28, 2011
    Henderson, NV & Orient
  4. Allow Me.
    10,762
    12,567
    May 28, 2009
    Rancho Mirage, Ca.
    Yes they do, will be a little faster.
    sjohnson1097 Thanks this.
  5. Albertaflatbed
    Albertaflatbed Medium Load Member
    405
    1,169
    Nov 20, 2022
    Nisku, AB
    I use a winder most of the time. At my previous job it was not unusual to have 20 to 30 straps on a load. A winder made it alot faster.
    Sometimes if I only have a few i will roll them by hand if I'm chatting with a rigger or site worker.
    sjohnson1097 and okiedokie Thank this.
  6. sjohnson1097
    Thank you! Which winder do you use, if you don't mind me asking?
  7. loudtom
    loudtom Road Train Member
    1,717
    2,806
    Aug 26, 2016
    Winch Strap Winder
    This one works really well. It rips the DOT tape on the rub rail and it can squeak pretty loud while winding if you don't plan on lubricating it. Those are the only 2 issues that I've come across.
    Oh, and slow down your cranking towards the end so the hook doesn't whack your lower body parts.
  8. Kenworth6969
    2,979
    9,331
    Jul 3, 2020
    I use a portable winch Winder. Has made life so much nicer.
    Albertaflatbed and sjohnson1097 Thank this.
  9. kylefitzy
    kylefitzy Road Train Member
    4,752
    19,798
    Aug 12, 2007
    Kansas city,Mo
    I use a winder like this if I have a rubrail available. It takes up the least amount of room.
    IMG_6194.png If I don’t have a rubrail, it’s the old handjob method for me unfortunately.
  10. dumptruck89
    dumptruck89 Light Load Member
    79
    106
    Feb 27, 2015
    MA
    I got a cheap winder of Amazon. Works great for when I'm putting straps away. I usually just leave them on the winches on the trailer as I run local and do multiple loads a day. For that I bent some steel wire into a handle shape to roll them up quickly.
    sjohnson1097 and Albertaflatbed Thank this.
  11. A Bug
    A Bug Heavy Load Member
    941
    1,936
    Mar 15, 2014
    Sevierville TN
    You can buy a simple winder at the pilot flying j truck stops. If you have the space available then lay your straps out flat when you are unloading so that winding them up will be made easy, otherwise they will get tangled and require a lot of pauses and adjustments,
