Blow by
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by timoleague1, Feb 3, 2020.
  1. timoleague1
    timoleague1 Bobtail Member
    2007 kenworth T800 cat c15 475 with 180,000 on engine has a blow by
    no white smoke coming from stack only from blow by pipe
    what would have caused this
  3. SAR
    SAR Road Train Member
    2,756
    36,654
    Nov 26, 2011
    ND
    I'm assuming this is a twin turbo CAT?
    If it is, these engine will huff a considerable amount of blow by while idling. The engine rings are designed to work against cylinder pressure and seal the blow by off under load. CAT has had many complaints about excessive blow by on these engines. CAT also came out with a catch can/oil separator arrangement to install on the crankcase vent tube to catch the excessive oil and return it to the oil pan.
    My acert puffs like a locomotive and sprays oil underneath my truck, but only burns a gal of oil every 5,000 miles.
    Goodysnap, Diesel Dave and spsauerland Thank this.
  4. AModelCat
    164,498
    I think the catch can was more an emissions thing since crankcase vapours started counting against an engine at around that time.
  5. EtherOrBroke11
    EtherOrBroke11 Bobtail Member
    21
    12
    Jan 17, 2020
    It could be your air compressor or turbos. Disconnect the the air discharge line and see if puffing goes away. You can unbolt the the oil drain line one at a time from the the turbos and place drain lines or fabricated drain lines into bucket (since it will make a mess) and see if puffing goes away.
    Rideandrepair Thanks this.
