Blower fan
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mike216, May 29, 2021.
  1. mike216
    mike216 Bobtail Member
    44
    13
    Dec 15, 2013
    Cordova,Md
    I have a 2016 T880 and the a/c fan motor at times will not reach full speed.I have installed a new motor and blend door actuator and still at times motor will not go to full speed.The filters have been replaced.Evaporater cleaned and all actuators for inside air,vents,and defroster are working.Any ideas?
  3. Arctic_fox
    4,506
    25,419
    Sep 16, 2016
    Bad switch likely. Had a 660 a few years back that had the same problem and swapping the switch fixed it. Could also be a short someplace.
  4. Rideandrepair
    17,548
    56,859
    Aug 8, 2015
    I’d suspect the blower resistor
    FLHT and truckdriver31 Thank this.
  5. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    good answer. either its high or low. no in between
    Rideandrepair Thanks this.
  6. Banker
    Banker Road Train Member
    4,504
    14,529
    Aug 19, 2012
    I have a 2015 389 and had sporadic issues with my blower not working on high speed, then the defrost not working on the dash only setting and finally the push button for A/C would not stay on. The A/C Heater control module took care of all of my problems. Yours may or may not be the same issue as mine.
    krupa530 and Rideandrepair Thank this.
  7. mike216
    44
    13
    Dec 15, 2013
    Cordova,Md
    You have to replace the whole module or just the switch?
  8. mike216
    44
    13
    Dec 15, 2013
    Cordova,Md
    Dealer said the resister is on the new motor.
  9. Banker
    4,504
    14,529
    Aug 19, 2012
    Entire module. I couldn’t find an aftermarket in my year, which are much cheaper than OEM.
  10. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Need to first check for HVAC fault codes and software updates.
