Blower motor 4th speed
Discussion in 'Volvo Forum' started by DUNE-T, Jul 15, 2019.
  1. DUNE-T
    DUNE-T Road Train Member
    7,044
    17,158
    May 10, 2015
    Detroit, MI
    2000 Volvo the front blower fan only works on three speeds. Changed the blower, resistor on top of it and nothing helped. What else can be checked?
    KB3MMX Thanks this.
  3. mladen86
    mladen86 Medium Load Member
    303
    269
    Aug 23, 2012
    Chicago,il
    Maybe the switch.
    flood Thanks this.
  4. Benek
    Benek Light Load Member
    83
    39
    Feb 10, 2016
  5. Humblepie
    Humblepie Pontificator
    5,077
    80,318
    Dec 25, 2018
    I don’t know about Volvo, but my international has a separate circuit breaker for high speed. Check there first
  6. DUNE-T
    7,044
    17,158
    May 10, 2015
    Detroit, MI
    I'll try swapping the switch, thanks, was putting it off, cause it looks like it's a pain in the butt
  7. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    The fan is on its way out.
    I've had this happen a few times and a new fan fixes it if the resister module didn't do the trick.
  8. benrab
    benrab Medium Load Member
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    Two question for you. Is the fan speed is the same on 3th and 4th position ? Do you have a manual control or automatic (with degree numbers) for heater operation ? Ben
  9. DUNE-T
    7,044
    17,158
    May 10, 2015
    Detroit, MI
    Update on this. The harness connector from the blower to the truck was bad.
    KB3MMX and Newto Trucking Thank this.
  10. KB3MMX
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    Thanks for the update !! Good to know
