blowing black smoke
Discussion in 'International Forum' started by TruckerPete1990, May 10, 2015.
  1. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,382
    Jul 16, 2012
    Bentonville Arkansas
    I have a 2007 int 9400i Cummings isk 435 about 602k miles. It seems she's blowing black smoke as it's on front of my new trailer... I'm a new owner op and got no clue what to do for it. My oil level is not dropping.
  3. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    You probably need 6 new spark plugs. I would start there then check your ground wire.
    TruckerPete1990 Thanks this.
  4. TruckerPete1990
    8,623
    5,382
    Jul 16, 2012
    Hey now... I'm not that new lol it don't have spark plugs.
    DetroitSpecial and Skate-Board Thank this.
  5. Skate-Board
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    I'm guessing it's one of your sensors like barometric or oxygen. I think a dealer could find the problem in minutes.
  6. 062
    062 Road Train Member
    6,326
    33,966
    Oct 20, 2013
    Have you checked air to air for leaks?
    jimbo47 Thanks this.
  7. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Try unplugging the egr valve and see what happens. ISX sensor typically plug up over time and need replacement or cleaning. Sensors such as exhaust pressure, egr differential pressure and intake manifold pressure are the main ones.
  8. TruckerPete1990
    8,623
    5,382
    Jul 16, 2012
    I'm prob catch slack for this. Where is the egr value? I've read that I should turn truck to on position then unplug it.
  9. Heavyd
    7,826
    6,276
    Feb 4, 2009
    Right hand side, just below the front of the exhaust manifold. It is the two wire connector. Do this at key off. Having it unplugged will cause a check engine light. Basically the egr valve is probably stuck open. This is leading to lower boost and excessive black smoke. Usually when the valve is stuck open the position sensor will detect this and log a code. Some times the valve opens because it is damaged internally, but the position sensor thinks it is closed. Unplugging it with the key off is the best chance of it being closed on its own.
    Rusty970 and TruckerPete1990 Thank this.
  10. TruckerPete1990
    8,623
    5,382
    Jul 16, 2012
    Thanks I Will give this a try. I haven't seen any today. To be honest I've never seen it but I've had the trl for 3 days n it's black lol.
  11. TruckerPete1990
    8,623
    5,382
    Jul 16, 2012
    I took a paper towel n put it inside the exhaust. It's dryed black stuff. Almost like soot? My air intake is reading 116-140℉ air temperature. I was reading it should be close to the temp outside? It's like 50-60 out
