Blowing the same fuse immediately
Discussion in 'Mack Forum' started by Echioffe, Jun 25, 2023.
  1. Echioffe
    Echioffe Bobtail Member
    Evening. I got a Mack RD690s Mixer Truck with a Bridgemaster 3 setup. The truck was stolen last September and the theif Nuked the Motor and Transmission in less than a mile. The it took 8 months to get it back. After a Level 4 overhaul, new transmission, clutch, radiator, and other miscellaneous parts. I before the overhaul the Cruise control stopped working. The dealership assure me it was fixed. Which it was NOT. I checked the #17 fuse and it was blown. Which I suspected. I wasn't prepared for the new fuse and the one after that to blow the second it touched the connects in the fuse box. I tore the dash apart and I believe the problem. Is from bad wiring on the cruise control switch. I need a wiring diagram for the cruise switch so I can get this soldered and running how it's suppose to.
  3. AModelCat
    164,481
    Probably not going to find much info for that online. Best bet follow the wire, look for a dead short. Should be pretty easy to spot.
    Siinman Thanks this.
