Blown head gasket??
Discussion in 'Ask An Owner Operator' started by wadeenterprisesllc, Apr 19, 2024.
  1. wadeenterprisesllc
    wadeenterprisesllc Bobtail Member
    11
    6
    Jun 9, 2022
    Coolant bottle absolutely CHURNS when I rev the rpm’s up. Combustion test came back negative for exhaust in coolant…new bottle, hoses, radiator, and water pump last year! EGR is dry as a bone. Thermostat stuck open maybe??
    Rideandrepair and Tug Toy Thank this.
  3. lester
    2,956
    8,078
    Jan 2, 2012
    NW, Iowa
    What truck? What engine?
  4. wadeenterprisesllc
    11
    6
    Jun 9, 2022
    2015 Cascadia DD15
  5. Opendeckin
    Opendeckin Medium Load Member
    495
    1,382
    May 20, 2018
    Could be the air compressor if there's no combustion gases
  6. wadeenterprisesllc
    11
    6
    Jun 9, 2022
    I also wondered that but wouldn’t air compressor push the coolant into the overflow from the high pressure?
    Rideandrepair Thanks this.
  7. wore out
    wore out Numbered Classic
    17,305
    214,670
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Look for black specks floating around in coolant. If you have them it’s a sure sign of combustion gas. The combustion gas kit has been known to lie on all makes all models
    Ssgtkevin, W923, Deere hunter and 6 others Thank this.
  8. AModelCat
    164,540
    Those combustion leak testers are trash IMO. Never had one work yet. Even a little Perkins with a 1" long crack between the valves didn't make it change colour.
    I'd rule out the air compressor first.
  9. Rideandrepair
    17,548
    56,859
    Aug 8, 2015
    My 12.7 did the same thing. No bubbles or excessive pressure at idle. Increased with RPMs. Coolant would blow out overflow while running to a point, then quit. Meanwhile it was also leaking into oil pan. It will separate and settle on the bottom. Might want to let it sit a little while. drain a bit, see if there’s any coolant in oil.
    Jordonh and wadeenterprisesllc Thank this.
  10. Antinomian
    Antinomian Road Train Member
    2,171
    3,441
    Feb 17, 2013
    Are you losing coolant?
