Blown tire simulator....
Discussion in 'Experienced Truckers' Advice' started by MACK E-6, Sep 15, 2016.
  1. MACK E-6
    49,921
    237,238
    As much as I absolutely bristle at the idea of new regulations of any sort, here's one that might actuallt make a bit of sense, as opposed to these bought-and-paid for "sleep study" rules where they're only too happy to require you to buy this expensive machine or you'll be out of a job.
    We all know what a hazard a blown steer tire can be. I think they're should be a way to simulate this experience in a controlled environment away from the motoring public so when this happens to an inexperienced driver, they're not subject to an instantaneous trial by fire which has a tendency to lead to people getting hurt and/or killed.
    Thoughts?
    Lepton1 and texasbbqbest Thank this.
  3. diesel drinker
    diesel drinker Road Train Member
    1,157
    1,235
    Apr 10, 2015
    Ehh blown steer is not a big deal.Had it happen in both 4 wheeler and a semi and handled situation well in both cases.In a semi it actually happened on I 80 in OH with a semi right in front of me and another right behind.And I am not an experienced truck driver.
    I mean what are they going to simulate?How to hold steering wheel straight with both hands and let the truck lose speed without breaking?Waste of time IMO.
    ramblingman Thanks this.
  4. MACK E-6
    49,921
    237,238
    Well, natural instinct is to hit the brakes, and that's where the newer guys fail.
    Having this happen in a loaded dump truck or something like that could probably be the worst of all, where you're likely putting 16k to the ground on the steer.
  5. texasbbqbest
    texasbbqbest Road Train Member
    1,088
    1,962
    Dec 9, 2014
    Minneapolis, MN
    I disagree. I think any training in a controlled environment is good training, and it should be required of all drivers annually. You could do catastrophic maintenance failures, weather emergencies, driving mountains/traffic/construction. It may sound like a waste but its always good to have an EXPERIENCED driver check you out.
    Pilots do it twice (or more) a year.
    Lepton1 Thanks this.
  6. AModelCat
    163,857
    College I got my license through made me spend a few hours in a simulator before they'd put me in an actual truck. Was the coolest thing ever. Was fairly accurate (well as accurate as a simulator can get). Instructor could blow out tires, change weather conditions, cause brake failures etc.
  7. diesel drinker
    1,157
    1,235
    Apr 10, 2015
    Sure training won't hurt.All I am saying is if you actually driving and not watching movies on your laptop you will immediately notice you lost tire and the truck will slow down without you breaking.Then it's simple stuff, foot off gas pedal,both hands on the steering wheel and let it roll to complete stop.Thats all,not rocket science.
  8. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,142
    Mar 5, 2016
    White County, Arkansas
    A proper skidpad set up with a run out and a run in plus a system to explosively drain steer tire air and so forth will be the best ever to a student.
    Ive had tires go all around except steer and usually for me it's a bomb. BOOM. never ever stab or stomp your brakes, she will settle and then pull that away to the blown wheel.
    This brings in a lesson number two, ease her back on the shoulder carefully if you come off it. (I have...) because if you horse it back to hard you are going to go into the oppositing side for a head on or overturn once you bounce across median or crown.
    If a tire is going to get me those are the ones that escape detection while losing or lost air very slowly. Next the you wonder what is going on with that extra bit of rpm to keep your governed speed... then you think.. oh, maybe check all the tires. In the olden days you checked all of them every 3 hours and on every mountain top. Tires today when brand new are so much more stronger in a number of ways than the old ones were. But to take care of them is one of the best things you can do.
    texasbbqbest Thanks this.
  9. MACK E-6
    49,921
    237,238
    Sure, for someone that's happened to before.
    It would be nice though to give rookies an idea of what to expect, or even a veteran that's never had that happen to them, of which I am one.
    x1Heavy, Lepton1 and texasbbqbest Thank this.
  10. Big Don
    Big Don "Old Fart"
    17,996
    35,644
    Sep 8, 2007
    Utah's DIXIE!
    I'm ALL for that, every training school should have this. And it wouldn't hurt to have refreshers on it!
    No, it's not rocket science, but take a look at what is coming out of high school. People who are lost if their tablet or phone takes a dump. People are not taught to use their heads, they depend on electronics to do their thinking for them.
    OLDSKOOLERnWV and texasbbqbest Thank this.
  11. dca
    dca Road Train Member
    6,834
    11,428
    May 31, 2011
    Earth
    I've been on a simulator where among other situations a blown steer tire was in the mix, a quick jerk to the right into field but I managed to miss the tree
