Boat securement
Discussion in 'Flatbed Trucking Forum' started by Tmichael2332, Aug 1, 2018.
  1. Tmichael2332
    Tmichael2332 Light Load Member
    67
    32
    Jan 9, 2014
    Picking up 2 boats on trailers. One is 22 feet the other 24. What’s the best way to secure them?
  3. cjb logistics
    cjb logistics Heavy Load Member
    766
    643
    Aug 13, 2016
    Liberal Ks
    Add water to trailer and moor them down?
  4. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    Skipper says if you can’t tie knots, tie lots!
  5. Tb0n3
    Tb0n3 Road Train Member
    4,736
    9,646
    Oct 5, 2012
    Earth
    Isn't there usually securement boat to trailer bow and stern?
    Zeviander Thanks this.
  6. beastr123
    beastr123 Road Train Member
    2,947
    24,178
    Jan 2, 2014
    Moose Jaw SK CAN
    insure that the boat bow is winched up tight and tied down and at least 2 1 inch straps from stern to boat trailer. then tie each trailer to your bed with a minimum of three tie-downs each
    Tmichael2332 Thanks this.
  7. Snakeschasingcars
    Snakeschasingcars Heavy Load Member
    743
    1,570
    Mar 22, 2018
  8. SixShooterTransport
    SixShooterTransport Light Load Member
    274
    559
    Mar 4, 2018
    What he said ^^^ should be done by the shipper. Good idea to double check that it’s all secure. The length of the boat is irrelevant, you need to know the total length from the tongue of the trailer to the rear of the motor. Since the boat is secured to the trailer it counts as one big piece. That will tell you how many tie downs you need. Over 20’ but under 30’ gets four, over 30’ but under 40’ gets five. Ask the shipper where you are allowed to tie them down. Most likely it will be one around the rear axle, one over the tongue, and two more somewhere on the trailer frame. Don’t forget carpet or some kind of padding to protect the paint from being scuffed by your straps.
    Tug Toy and Tmichael2332 Thank this.
  9. kurbski
    kurbski Light Load Member
    284
    644
    Jul 6, 2008
    NE Florida
    Might want to chock wheels as well or throw a couple extra small straps over axles that minimize any movement. If the rules say use 4, I usually put on 8.
  10. johndeere4020
    8,522
    119,295
    Jan 1, 2010
    The every ten foot rule doesn’t apply here, it’s based on weight just like machinery
    ChaoSS, TripleSix, stwik and 2 others Thank this.
  11. Zeviander
    Zeviander Road Train Member
    4,886
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    Straps over top like everything else, no? Maybe chains? DOT says the thing on the trailer can't move. Might as well use chains just to be safe. Make sure to crank 'em down real tight.
    Seriously though, they have securement points for shipping don't they? Boats I see usually move on specially designed trailers.
    stwik Thanks this.
