bobtail valve leaking
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Undone, May 11, 2015.
  1. Undone
    Undone Bobtail Member
    4
    I have a 94 volvo single rear axle, I've replaced both brake cans and the bobtail valve but the valve is still leaking air out the relief. ...what do I look at next?
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,541
    6,619
    Aug 26, 2014
    What is the bobtail valve and what valve is still leaking air out the exhaust?
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    I'm confused as well. Do you have a separate bobtail ratio valve, like an LQ-5? Or do you have a bobtail proportioning relay valve? Were exactly is the leak? When is it leaking? All of the time? Only with the spring brakes released? Only with the service brakes applied? Need more info.
  5. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    You sure it is not a leveling valve?
    KW Cajun Thanks this.
  6. KW Cajun
    KW Cajun Road Train Member
    2,383
    3,652
    Apr 12, 2013
    Copperhead Road
    You beat me to it. That's what I was assuming he was trying to say.
  7. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    Pictures are worth a 1000 words.
  8. cnsper
    5,869
    27,421
    Feb 28, 2014
    That's funny, mine are only worth about 27 words....:)
    icsheeple Thanks this.
  9. Undone
    4
    It's a Bp-r1 valve. Leaks air out the bottom relief when you release the tractor brakes and get ready move. It's connected to the service side of the brakes, from what I've read supposed to make breaks less aggressive when not pulling a trailer.
  10. Undone
    4
    And only leaks when spring brakes are released.
  11. BoxCarKidd
    4,541
    6,619
    Aug 26, 2014
    Disconnect the lines from the chambers and the control port. Chalk wheels, build air and release parking brake. Nothing should leak air. Air from chamber hose, bad chamber. Air from control hose, could be swapped with supply hose,( other hose on top of valve) or some thing is sending control air when it should not. Start by checking for brake pedal or piston under it sticking. No air leak from lines, new valve is bad.
