boost pressure gauge install
Discussion in 'Trucks [ Eighteen Wheelers ]' started by JimmyO, Nov 5, 2011.
  1. JimmyO
    JimmyO Bobtail Member
    10
    Oct 24, 2011
    cornfields, indiana
    05 KW isx 475... I want to install a boost gauge, I have an empty hole in my dash and I am looking for a factory kw boost gauge, question is... how do I hook it up, were these mechanical or electric. Any info would be great, thanks guys.
  3. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Not sure about the KW, but they either used a mechanical gauge with an air line plumbed into the intake manifold somewhere, or an electronic gauge. The mechanical gauge shouldn't be too hard to install. If it needs to be electronic the easiest way is to see if the wiring and plug for the gauge is already there and it is just a matter of installing and plugging it in. I see a call to your local dealer in your future!
  4. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    Should be mechanical.... look for a 1/4" plug south of the charge air cooler on the intake. Guage should come with plumbing too.
    Do like Heavy said and snoop behind the dash for the plug in..... be the easiest way if it's electric and hooked to the ECM.
    JMO
  5. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    I have an 05 w900l with a cat and my gauge is mechanical. Just call the parts guys at Kenworth for a gauge and some tubing. They can even show you on their computer where it hooks into the intake. It's easy, and no truck should be built without one.
