Box van antenna mounting
Discussion in 'CB Radio Forum' started by Wsimmons5445, Nov 28, 2019.
  1. Wsimmons5445
    Wsimmons5445 Bobtail Member
    I drive a small box van. Currently using a 28 inch magnetic mount antenna with my Midland 75-822. I can receive about a mile to mile and half out. I am looking at the firestik antennas. My problem is I can't do any cutting to the van. I'm looking at possibly using the drip rail above the passenger side door or the mirror for mounting. The mirrors however have plastic arms.
    Anyone have any ideas to what could be done or used?
  3. Ridgeline
    22,720
    123,212
    Get a three magnet mount and get a good antenna, firestick should do. Don't bother with gutter mounts or anything like that, this isn't 1975,
    Meteorgray Thanks this.
  4. Meteorgray
    Meteorgray Heavy Load Member
    754
    597
    Jan 1, 2016
    Get the tallest antenna you can stand. The performance is linear: the taller, the better. The CB is dealing with a big 36-foot shortwave signal, and a 28-inch antenna will cut performance down to almost nothing.
    A quarter-wave, nine-foot "whip" antenna would be the best as far as mobile performance goes, with a seven-foot Firestick just behind. Both would need the big tri-magnet base Ridgeline mentioned. However, these are really tall antennas for a vehicle and might hit a lot of things overhead, and the three-magnet base might be hard to put on and take off.
    Perhaps more practical would be the great Sirio 5000 single-magnet base mount at 6.6 feet, or the Wilson 1000 at 5.2 feet. They are not far behind the tall boys in performance, and are more practical when it comes to hitting things overhead and putting them on and taking them off the roof when needed.
  5. Wsimmons5445
    Thanks for the replies. So I'm stuck with a whip style antenna. I have a hard time finding a spot suited for setting the swr around the Atlanta area. Part of why I was looking at the firestik. I've been seeing how easy and foolproof it is to set the firestik.
    I'll look into some of the antennas mentioned above.
  6. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Fender mount the antenna...Ran this dual coil Predator 10K on my work van for years, running a 2x6 pill Davemade...worked out just fine! Had to make my fender mount, but fender mounts are available for some vans and trucks...just have to google around...
    The mount attaches under the hood to the inside of the fender, and sticks up between the fender and hood...then you can have a ball mount or swivel type mount for the antenna so you can tilt the antenna to the right angle so it's straight up and down.
    stacks and shogun Thank this.
  7. stacks
    stacks Road Train Member
    1,546
    850
    Oct 27, 2011
    Emerald Isle
    nice Antenna setup there
    jessejamesdallas Thanks this.
  8. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    On that van I was really limited where to mount a antenna...had to fab my own bracket...SWR was pretty close to flat, and could talk back to whoever I could hear...May not have been the best location for a CB antenna, but not every instal is going to have perfect conditions for a antenna, so you have to do the best you can with what you have to deal with.
    stacks Thanks this.
  9. Wsimmons5445
    Looks nice but I know the boss would have a fit if I did something like that to the van. Clearing the box is my concern. Aluminum sides and top on the box. Im not too familiar with cb terms and I just now getting into it.
  10. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    you could use whatever antenna you want...Mounting like I did with a fender mount, no-holes are visible on the outside of the van...any holes that may need drilling would be under the hood in the engine compartment...In my case, I didn't have to drill any holes! Like I said, I fabbed-up my own bracket using scrap flat bar metal I already had, then mounted the bracket using bolts already under the hood using some of the bolts used to attach the fender...Might have had to drill one hole on the inside of the fender but it was under the hood where once removed you wouldn't be able to tell there was ever a antenna mounted...Only other less aggressive mounting option would be to figure out some way to use a magnet mount...good luck with that on a box van.
  11. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    A short Wilson 5000 in the middle of that huge roof will outperform the long antenna on the small front fender.
    Meteorgray and jessejamesdallas Thank this.
