Brake chambers..
Discussion in 'Ask An Owner Operator' started by White_lightning1983, Feb 29, 2020.
  1. White_lightning1983
    White_lightning1983 Light Load Member
    54
    27
    Aug 1, 2019
    So, I had a break chamber blow.... I didn't think they did.... I had one truck prior to owning my current truck and never had a break problem.... I know that they are all cheap chinese garbage parts (frieghtliner cascadia 2016).. I was thinking of replacing all 6 with Bendix or betterquality chambers so I don't have to worry about it ever again or for at least 300-500k miles.
    Any thoughts on this?
    Thanks.
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,143
    Mar 5, 2016
    White County, Arkansas
    If it's the rubber divider inside the chamber that got a hole in it then the quality of your service air is contaminated. The symptom is rapid loss of primary followed by secondary at the same time as you apply service braking.
    Buying parts is nice but not when you think it will be the end all of forever no problems. Ive been wrestling with less than reliable batteries each winter even though the vehicle in it has zero drain anywhere. (Found the hood light the other day...) I will be replacing the battery etc in March. And that should be good for a few years.
    TallJoe and Cabinover101 Thank this.
  4. White_lightning1983
    54
    27
    Aug 1, 2019
    I just don't want this to happen again .. if I get quality parts. And replace them every 300-500k miles. I've been told they are called pancakes. I've been told the break chambers on the steers don't get used nearly as much. But I think I have all original parts on breaks minus that one that got replaced.
    Cabinover101 and x1Heavy Thank this.
  5. x1Heavy
    34,016
    42,143
    Mar 5, 2016
    Take a fresh look at your air dryer and also drain your air tanks manually to see if you have excessive gunk in them.
    Cabinover101 and ChevyCam Thank this.
  6. White_lightning1983
    54
    27
    Aug 1, 2019
    Air dryer? Is that the air bag? Or is that something else? I'm still new here... Sorry
  7. AModelCat
    164,393
    At most, I'd just change the pair on that axle and send it.
  8. x1Heavy
    34,016
    42,143
    Mar 5, 2016
    Its ok, Im new too. lol. ANyway the air dryer is somewhere near your catwalk tied into your air brake system. It cleans air and when it does it farts every so often. If it got to where it is constantly passing then it needs a look see.
    If you do NOT have ANY air dryer at all, then I will bet the farm that your wet and dry tanks got gallons of sludge in them. Thats why I lost my pancake when I did, failure to drain those tanks every night without a airdryer truck. No one taught me about that. (They sure did after...)
  9. White_lightning1983
    54
    27
    Aug 1, 2019
    On the steers or the back 4 with the drive tires?
  10. Opendeckin
    Opendeckin Medium Load Member
    494
    1,379
    May 20, 2018
    It's just a piece of rubber. sometimes they're gonna blow. You don't even need to replace the brake can. You can just take it apart and put in a new pancake pretty easy. I've done it twice.
    TripleSix and Big_D409 Thank this.
  11. White_lightning1983
    54
    27
    Aug 1, 2019
    Ok it farts every so often when it gets full. It doesn't do it all the time just once in a while. Seems normal.
