Brake lag?
Discussion in 'Ask An Owner Operator' started by TheLoadOut, Mar 7, 2021.
  1. TheLoadOut
    TheLoadOut Road Train Member
    2,412
    11,559
    Nov 6, 2019
    Anybody ever noticed a bit of a brake lag on their first push down on the peddle, but the 2nd push seems to have a better reaction by the brakes?
    Trucker61016 and 77fib77 Thank this.
  3. 77fib77
    77fib77 Road Train Member
    11,639
    76,714
    Jul 7, 2010
    St Louis
    Yep.
    Trucker61016 and TheLoadOut Thank this.
  4. Ridgeline
    22,717
    123,141
    That’s the nature of air brakes, one reason why you take a test not to have any restrictions on your license.
    Trucker61016 Thanks this.
  5. 201
    201 Road Train Member
    12,760
    26,253
    Apr 16, 2014
    high plains colorado
    Juice brakes, yes, air brakes, should be no lag, none that I ever encountered. Again, moisture somewhere could do that.
  6. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
  7. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    I've always noticed just a tiny tiny bit of lag to when the trailer grabs.
    77fib77, Trucker61016 and TheLoadOut Thank this.
  8. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    nope, not normal. should react the same at the first push. That sounds like 100 percent foot valve issue. Put a new one in
  9. AModelCat
    164,498
    Air brakes have about 0.3-ish seconds of lag time. Takes time for the air to flow from the pedal to the relay valves and from the relay valve to the chambers. Then the chamber needs to stroke and either actuate the caliper or push on the slack adjuster and rotate the cam to push the shoes into the drum.
  10. SmallPackage
    5,777
    18,542
    Dec 20, 2019
    Marion Texas
    Also depends on the type of valves and the crack pressures they have. A R12 relay valve has a hair more lag then an R14. Some may have a 1 psi crack some have a 3 psi. Also some antilock systems valves are “lazier” then others.
    Snailexpress and TheLoadOut Thank this.
  11. TheLoadOut
    2,412
    11,559
    Nov 6, 2019
    Thanks, I think I'll do that.
