brake question
Discussion in 'Questions From New Drivers' started by revensmj, Dec 18, 2009.
  1. revensmj
    revensmj Light Load Member
    59
    33
    Dec 10, 2009
    las vegas nevada
    what does the term or phrase brake dynamite mean
  3. blackw900
    blackw900 The Grandfather of Flatbed
    5,817
    7,678
    Jul 12, 2009
    A.W.O.L
    Never heard that one....
  4. stranger
    stranger Road Train Member
    3,640
    4,959
    Oct 10, 2006
    NC
    You blew up the brakes?
    Could it be brake dynamic?
  5. SLCTrucker
    SLCTrucker Medium Load Member
    404
    199
    Jan 15, 2009
    Salt Lake City UT
    BTS Transportation Expressions
    Dynamite the Brakes
    Emergency stop using every brake on the unit. (ATA1)
  6. Allow Me.
    10,756
    12,531
    May 28, 2009
    Rancho Mirage, Ca.
    "Using every brake on the unit", as opposed to only using, what, 3 of 5 axles?
  7. Jack Smithton
    Jack Smithton Light Load Member
    256
    167
    Jan 1, 2009
    so cal
    The phrase is more common in railroading - I believe "Dynamite the brakes" means to make a full brake application by releasing (dumping, in an explosive way) all of the brake pipe pressure throughout the train. This results in a full brake application. Maybe a railroader can clarify (I know some laid-off railroaders turned to trucking) . . .
  8. Powder Joints
    7,962
    8,326
    Sep 25, 2007
    Rosamond, SoCal
    It would be the equivalent of popping both red / yellow brake knobs on your dash in a truck. Not highly recommended. Maybe if you were passing out / stroke / heart attack or something, but still not going to have a good outcome/
  9. mikemotorbike
    mikemotorbike Bobtail Member
    5
    Oct 3, 2017
    (I'm only studying for the written test. Please confirm all selected info for your own safety)
    "Dynamiting the brakes": sudden application of brakes (service or spring)
    -line rupture/pressure falls too low
    -disconnecting the gladhands
    -closing the trailer supply valve
    some good news: Losing air pressure to the trailer while moving can result in a controlled stop because: the primary and secondary reservoirs' air is blended with a two way check valve, a "spring break modulator" is on the spring breaks,
    Bad news: dynamite on a trailer equipped with a relay emergency valve on the service brakes that don't have spring brakes.
    British Columbia, Canada Gov.
    "Driving Commercial Vehicles"
    -pages 166, 168,158,163
    http://www.icbc.com/driver-licensin...rcial_veh_full.pdf#page=182&zoom=auto,-15,783
    pg 166
    Screenshot-2017-10-24 Driving Commercial Vehicles Manual - drive_commercial_veh_full pdf(1).png
    pg 168
    Screenshot-2017-10-24 Driving Commercial Vehicles Manual - drive_commercial_veh_full pdf.png
    pg 158
    Screenshot-2017-10-24 Driving Commercial Vehicles Manual - drive_commercial_veh_full pdf(2).png
    pg 163
    Screenshot-2017-10-24 Driving Commercial Vehicles Manual - drive_commercial_veh_full pdf(3).png
    Reason for edit: correcting page numbers, double checking data
  10. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,142
    Mar 5, 2016
    White County, Arkansas
    To understand dynamite is to go to railroad. Engine stores air in a big tank. Each freight car has one airline through all the way to the end of train. There is a second airline for purposes of brake application, known as the train line.
    The closest analogy will be our trucking red and blue service air connections to the trailer.
    Lose the trailer it will dynamite into spring application asap and really hard.
    A railroad car if it fails to hold pressure BOOM dynamite. That one car would become to use a bad analogy a troublesome truck from Thomas the Tank Engine cartoon. It will get onery and mean wanting to derail it's neighbors. Because it has dynamited, the pressure is falling fast on the trainline. Engineer will have to pretty much take the horses off the drives and apply to stop the train while he still has the control to do it. Like right now.
    Then get out of the engine and walk back potentially two miles and 150+ cars to find the one that dynamited.
  11. Hoofbeats
    Hoofbeats Road Train Member
    1,250
    1,991
    Jan 27, 2010
    Iraq
    All train cars have air tanks. When air is lost,they go into Emergency Stop, just like we do. Oddly, the usually run 85-90psi,less than we do.
    x1Heavy Thanks this.
