Brake service line question.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Deezl Smoke, Jun 18, 2014.
  1. Deezl Smoke
    Deezl Smoke Medium Load Member
    539
    356
    Feb 12, 2011
    Hillsboro Oregon
    Using a mid 90s truck as an example, if you apply air pressure to the glad connection on the truck where it connects to the trailer, can you apply the truck brakes?
  3. 201
    201 Road Train Member
    12,771
    26,266
    Apr 16, 2014
    high plains colorado
    Hi Deezl, you mean, apply the wagon brakes with the "johnny bar"? You should be able to still apply the truck brakes with the foot pedal.
  4. Deezl Smoke
    539
    356
    Feb 12, 2011
    Hillsboro Oregon
    Well, I had a hair brained idea that I was trying to work out before going any further. I have a dead semi that I was going to leave the cab on and use as a trailer for personal rv use. I got to thinking maybe it would be easy to hook up the brakes to the towing truck and have things act just like an actual trailer. But it sounds like I can air up the dead semi with the emergency line, but activating the brakes will take some valve bypassing. Especially the treadle valve, and the protection valve.
  5. bowtieboy77
    bowtieboy77 Light Load Member
    274
    82
    Aug 16, 2013
    Southern, Ontario
    Why not just install a mutifunction valve and put full chambers on the axles. The multifunction valve supplies air to release brakes and air for service brakes. Its the same valve used in most trailers.
  6. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    no.if you apply pressure to blue glad hand and truck service brake is not applied, trailer control valve (under cab usually) is open and air will go out throught valve exaust
    EverLuc Thanks this.
  7. Rooivalkpilot
    Rooivalkpilot Bobtail Member
    24
    Jan 16, 2014
    ahh nice one. You have a dual line system available at the back of the towing truck right?
    I would connect the emergency (red hose) to the supply port of the 4 way/multi circuit protection valve (port1)
    to connect front brakes on dead semi. cut pipes going to the brake chambers "t" with pipe that you install at port number number 2 (delivery) on the relay/load sensing valve at the drive axles.
    then connect your service line from the towing truck to port number 4 (service) on the relay/load sensing valve.
    and the truck will react like a trailer.
    hope this help
    ps: make sure the park brake is released on the dead semi. because it will still function. or remove the park brake and connect the pipes direct on each other (bypass it)
