Brake spider
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by insanityeight, Jun 13, 2020.
  1. insanityeight
    insanityeight Light Load Member
    291
    113
    Jul 26, 2013
    birmingham al
    2016 pete 579. New hub new drum and new shoes for about third time.. I adjust shoes tight and back off one notch at a time but when spinning the wheel it still ever so slightly rubs in one spot when turning. Is it just new shies need to wear in or is my spider somehow out of correct position? . Im tired of throwing drums and shows on this one front steer tire to try to stop the horrible vibration when bracing . At my wits end
  3. bad-luck
    bad-luck Road Train Member
    3,426
    6,311
    Nov 16, 2013
    Baltimore, Maryland
    Rule of thumb. When adjusting the breaks, run the slack adjustment nut (5/16) all the way in, then back off 1/4 to 1/2 turn.the breaks should not be dragging at this point and your breaks will be properly adjusted.
    Coffey, lwlevens and insanityeight Thank this.
  4. AModelCat
    164,290
    1 and a half turns? No no no. 1/4 to 1/2 turn. Dollars to donuts you'll be close to over stroking with 1 and a half turns.
    Besides, if the pushrod is cut right, they should stay in proper adjustment.
    Coffey and lwlevens Thank this.
  5. insanityeight
    291
    113
    Jul 26, 2013
    birmingham al
    If i back them off that far they dont drag. If i start tightening the breaks one notch at a time while spinning the tire and stop the moment i hear slight brake shoe rub, the rub is on the bottom shoe only but very minimal. Is that normal til i wear them in a few miles
  6. bad-luck
    3,426
    6,311
    Nov 16, 2013
    Baltimore, Maryland
    Speak texting don't know where the 1 came from any way, you are correct. I will change it But he is having an issue with premature wear
    Bean Jr. and AModelCat Thank this.
  7. bad-luck
    3,426
    6,311
    Nov 16, 2013
    Baltimore, Maryland
    No It sounds like an s-cam bushing. When s-cam bushing wears out the bottom shoe wears out 1st
  8. Rideandrepair
    17,532
    56,814
    Aug 8, 2015
    You can tell when the spiders bent. The shoes won’t fit evenly inside the drum. Easily seen from the back side. Shoes are normally a lot thicker in the middle when new. That’s probably where they’re dragging. They’ll break in, and match with the drums, in no time.
