brakes drag
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 66truck, Jan 16, 2026.
  1. 66truck
    66truck Light Load Member
    140
    34
    Nov 7, 2008
    ohio
    I have a 2003 international 9900i that when brake pedal is released the brakes drag for a few seconds, sitting still looking at the brake chambers they appear to work normally but going down the road they drag when released, any idea's?
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Truck brakes trailer brakes or both?
    Rideandrepair Thanks this.
  4. AModelCat
    164,565
    Check the quick release valve.
  5. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    Very nice looking 66. Did you do the paint yourself?
  6. 66truck
    140
    34
    Nov 7, 2008
    ohio
    Yes, and thanks
    OLDSKOOLERnWV and Rideandrepair Thank this.
  7. 66truck
    140
    34
    Nov 7, 2008
    ohio
    Already replaced
  8. 66truck
    140
    34
    Nov 7, 2008
    ohio
    Tractor only
  9. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    Thinking foot valve sticking but some seized clevis pins and or cam bushings could do that. Might want to put a gauge on the service side of a brake chamber and see if it is an air or mechanical problem.
    AModelCat and Rideandrepair Thank this.
  10. Rideandrepair
    17,550
    56,868
    Aug 8, 2015
    My Truck did that when it got cold out. Had to jab the pedal hard to make them release. Happened again much colder outside. Actually brought me to a complete stop on an exit ramp. Thanks to the forum, I sprayed the foot pedal plunger with PB Blaster till I could take it apart, cleaned the cylinder and plunger/piston with 240 then 600. Coated with light amount of anti sieze. Brake pedal application was so smooth afterwards.
    BoxCarKidd and 66truck Thank this.
  11. ElmerFudpucker
    6,968
    76,117
    May 17, 2024
    I’m willing to bet froze Clevis pins.
    Rideandrepair and AModelCat Thank this.
