Brakes Dragging
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Mr Mark, Dec 15, 2017.
  1. Mr Mark
    Mr Mark Bobtail Member
    have a problem my brakes are not release all the time I hear air back feeding on the dash valve when hooked to a trailer when I push on the brake pedal can hear leak out of quick release changed the quick release valve , relay valve , dash valve also the trailer parking brake when released takes a long time to stabilize when starting from a stop position air starts to back feed also noticed my front air tank drops faster then my rear tank when the truck is shut off
  3. Nestor
    Nestor Light Load Member
    160
    23
    Oct 21, 2015
    Did you ever figure it out
  4. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,130
    Mar 5, 2016
    White County, Arkansas
    Hell no.
    Not today. give me some time for the medicines to take a hold. Maybe I can get warped enough to understand this.... and I thought I was bad myself.
    I simply do not understand what that particular complaint is all about. To me a airbrake system on a tractor and trailer are pretty specific. But when written like that? I cannot begin to comprehend enough and would not help anyone by trying to untie this... this... gordion knot.
    GrapeApe Thanks this.
  5. bowhunter67
    bowhunter67 Light Load Member
    283
    549
    May 28, 2016
    rush city mn
    check your cans sounds like you have a hole in 1 of the diaphrams
  6. Nestor
    160
    23
    Oct 21, 2015
    I have similar prolblem . My brakes drag . I have to press my brake again to release them sometimes. One axle Brake pads are wearing out fast from it grabbing all the time . But only from the outside of brake pad not evenly .
  7. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    Anchor pins or S-cam and bushings or both.
    Oxbow and bowhunter67 Thank this.
  8. OZZ7986
    OZZ7986 Bobtail Member
    5
    Anybody ever heard of a Volvo truck not wanting to stop when brakes are pressed. The truck continues to power forward and then suddenly snatches to a dead stop.
