Brakes
Discussion in 'Questions From New Drivers' started by superdutyfan, Dec 27, 2020.
  1. superdutyfan
    superdutyfan Light Load Member
    86
    76
    Mar 14, 2020
    Hello everyone,
    Are there any benefits of drum brakes over disc brakes on the truck ?
    And do all trailers have drum?
    Thx SDF
    truckdriver31 Thanks this.
  3. Dondiego
    Dondiego Bobtail Member
    5
    Dec 5, 2020
    I think all flatbed trailers all have disc brakes.
  4. JonJon78
    JonJon78 Road Train Member
    7,239
    42,999
    Jul 1, 2018
    Not.
  5. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    drum fade. disc fade some. but drums are tried and true. truck disc and trailer disc is a nice set up
    Coffey and 77fib77 Thank this.
  6. Dockbumper
    Dockbumper Road Train Member
    3,778
    9,863
    Apr 29, 2020
    Where did you get that information?
  7. abyliks
    abyliks Road Train Member
    4,102
    9,639
    May 2, 2010
    ludlow MA
    It all depends on how the equipment is specd, the discs have only really been relevant the last few years (except for the ####ty bendix stuff of the 80s) My personal opinion is that the different crack pressures of the drum/disc things can get a little funky with them mismatched, but I will say, disc all around definitely stop on a dime and bring back change
    most dot don’t know anything about disc either
  8. Hulld
    Hulld Road Train Member
    2,884
    6,568
    Oct 19, 2015
    Upstate NY
    Drums hold up better in the rust belt states that use road salt.
    Drums are some what enclosed to keep out the salt but disc brakes are fully open to the elements.
  9. AModelCat
    164,481
    Disc brakes will fade. Its harder to get them to fade than drums but they will fade.
    I haven't seen discs last worth a crap if you work in mud. Not unless you actually wash them out good and often.
    I believe you have to actually remove the hub if you have to change the rotor.
  10. REO6205
    REO6205 Road Train Member
    13,168
    60,499
    Feb 15, 2014
    California.
    Read his profile. He's really green. He'll learn, given time and patience.
    Coffey, truckdriver31 and 88 Alpha Thank this.
  11. Brandt
    Brandt Road Train Member
    4,622
    6,355
    Sep 17, 2012
    Disc brakes are much better then drums in my opinion. They don't fade, I'm not sure how much heat they can take. They don't fade like drum brakes. You can probably overheat them and crack the disc. I like how no more slack adjuster to worry about not working. Disc brakes are upgrade on tractor and trailer when you order them from factory. They have better stoping power even when they heat up over drum.
