break lights not turning off
Discussion in 'Trucks [ Eighteen Wheelers ]' started by nakoBilly, Feb 1, 2012.
  1. nakoBilly
    nakoBilly Bobtail Member
    21
    10
    May 20, 2010
    Norwalk CA
    So this is the problem, brake lights won't deactivate at all...checked stop lamp fuse and replaced but it did not fix the problem.
    The brake lights will only go off when I remove the fuse.
    Is there a relay that I might be missing.
    Any help would be appreciated
    Its on a tractor kw t700
  3. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    Check the brake lite switch can't remember on a kw been a while but I think its under the hood near the foot valve hand brakes not on is it?
    nakoBilly Thanks this.
  4. dave26027
    dave26027 Road Train Member
    1,284
    804
    Sep 10, 2009
    Dallas, Texas
    Yup- the switch on the foot valve is bad- or for some reason won't release. Time to inspect or replace. Could be out of adjustment- if it somehow was moved closer to the linkage, if so it just needs to be moved back.
  5. Licensed to kill
    Licensed to kill Heavy Load Member
    830
    2,435
    Dec 31, 2010
    Alberta
    Check the spike, make sure it's forward all the way.
  6. Bill104
    Bill104 <b>Pepsiholic</b>
    719
    769
    Dec 27, 2011
    Sacramento,Ca
    Have the co driver take there foot off the brakes.
    Its going to be the presure switch on the brake valve unde the hood, use a test light to verify its getting voltage to both sides it should only have it on one side when brakes are released.
  7. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Make sure the brake pedal is up all the way too. This time of year a lot dirt and debris can build up at the base of the pedal and cause it to stick or not fully release.
  8. nakoBilly
    21
    10
    May 20, 2010
    Norwalk CA
    Thanks for the help guys. Will take a look at that switch
  9. dirthaller
    dirthaller Road Train Member
    1,126
    13,424
    Sep 22, 2011
    Coloratah
    make sure the hinge that holds the pedal to the floorboard isn't rusted and just hangin up
  10. Prairie Boy
    Prairie Boy Road Train Member
    3,258
    1,914
    Nov 18, 2010
    Edmonton, AB
    Sometimes the foot valve needs a good shot of WD40.
  11. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    Are the T700's different from the rest of the KW's? Everyone I've ever seen was on the inside of the firewall behind the dash panel. Either way nakoBilly it probably looks like this and Bill is correct it should only have power to one post with the brakes released.
