Brick Loads
Discussion in 'Flatbed Trucking Forum' started by randypinenc, Jun 6, 2020.
  1. randypinenc
    randypinenc Light Load Member
    59
    50
    Apr 21, 2018
    Any options (home made or otherwise) when hauling brick besides using those extra large Vboards as edge protection. I know they help keep the bricks in place but they are expensive!
    D.Tibbitt Thanks this.
  3. D.Tibbitt
    156,822
    @FoolsErrand has all the cool gizmos for those type of loads
    randypinenc, FoolsErrand and G13Tomcat Thank this.
  4. MACK E-6
    49,984
    237,851
    I believe @Ruthless once said tarps are required on brick in some states for that reason.
    cke, randypinenc, D.Tibbitt and 2 others Thank this.
  5. D.Tibbitt
    156,822
    A cheap one that. I could think of is cut a milk crate right down the middle.. Makes 2 v boards for each crate... alot of guys u see that haul brick loads for a living use fencing or metal v board
  6. Kyle G.
    Kyle G. Road Train Member
    3,901
    20,575
    Jan 23, 2016
    Eastern Iowa
    I used to drive for a particular company that hauled brick pretty regularly. We did it on the cheap, orange snow fence wrapped all the way around, and simple cardboard edge protectors. Seemed to work just fine.
  7. FoolsErrand
    FoolsErrand Road Train Member
    2,877
    12,169
    Sep 15, 2017
    Ill post some of my experiences later when i have more time.. I tried a bunch of stuff and the final method before i left the company was homemade wire screens from pallet racking. I loved them and used for a lot of stuff but it had its issues too.
    I think ruthless said CT requires tarp. A lot of times spot market brick will require a tarp to cover the middlemen. We hauled it all the time and neither the plants nor the states i was in had any specifics id ever heard of.
    randypinenc and D.Tibbitt Thank this.
  8. HillbillyDeluxeTruck
    5,951
    30,437
    Mar 3, 2013
    San Antone
    Sometimes tarps are required to keep road grime off its its raining. But they work good to keep bricks from going bye bye.
    Ive loaded a place where they had some plastic netting stuff that you used to wrap your load up. Seemed like a pain in the butt at the time, but sure did keep those bricks in place
    D.Tibbitt and randypinenc Thank this.
  9. randypinenc
    59
    50
    Apr 21, 2018
    The stretch wrap may work as well, cheap enough too.
  10. TripleSix
    133,196
    Use some old pallet slats and pieces of old strap and a box of tacks. Make a really cheap (as in inexpensive) V boards.
  11. Cat sdp
    Cat sdp . .
    21,285
    76,038
    Apr 8, 2012
    Orion's Belt
    Last couple loads of cheap heavy bricks I did was plastic wrapped from from the factory......:)
    D.Tibbitt and snowwy Thank this.
