Bridge Height
Discussion in 'Questions From New Drivers' started by DevJohnson, Jul 18, 2018.
  1. DevJohnson
    DevJohnson Medium Load Member
    340
    153
    Nov 27, 2017
    I’ll be running a trailer with a height of 14’ in three states Wa,Or,ID so being 14 am I able to go under a 14’ bridge or does it’s need to have some inches after that
  3. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    You should clear everything. Our van devision ,TWT, runs high cube vans all over the northwest. Just stick a tape measure on it to make sure your not to tall. If I remember right the high cube's have a max 5th wheel height of 47.5".
  4. okiedokie
    okiedokie Road Train Member
    13,779
    108,980
    Jun 13, 2011
    PNWET
    Your kidding right.
    Grubby Thanks this.
  5. Roberts450
    2,237
    3,638
    Feb 6, 2016
    14' is legal in the northwest without permits and a lot of 3/4 axle van run high cube and that puts you right at 14'. SOP up here.
    okiedokie and spyder7723 Thank this.
  6. okiedokie
    13,779
    108,980
    Jun 13, 2011
    PNWET
    Isn't it 14'1" before permits. It is the way the question was worded.
    so being 14 am I able to go under a 14’ bridge or does it’s need to have some inches after that...
    Yes you need a couple of inches to fudge. Sometimes they will put a lift/pave on an existing road and not change the sign. There are plenty of low bridges in the port towns along the West coast. Auto transport can be difficult when older established dealerships are in the old town.
    Grubby Thanks this.
  7. GreenPete359
    GreenPete359 Road Train Member
    2,243
    5,393
    Oct 21, 2017
    Driving my recliner
    The only stupid question is the one not asked. Take bath & lower your saltyness levels guy.
    Jeez. i’m 13’6” can i go under a 12’2” bridge? Well if your in New York, yes you can!
    DevJohnson Thanks this.
  8. DevJohnson
    340
    153
    Nov 27, 2017
    Thanks, wasn’t going to ask because I know how people are
  9. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Rule of thumb:
    1. Know exactly how tall you actually are. Use tape measure!
    2. If the bridge says 14'0". That is the maximum height they want going under there. You will be fine.
    I used to think the same in the eastern part of the country where 13'6" is the standard. Thankfully now I run the same stuff over and over so not many new roads for me.
    IluvCATS and DevJohnson Thank this.
  10. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    guess some of you never been threw pittsburg tunnel.
    IluvCATS Thanks this.
  11. Moose1958
    Moose1958 Road Train Member
    15,289
    33,945
    Dec 17, 2010
    Williesburg, Virignia
    Beware sometime those height signs are off. I would never trust a sign when I was that close. Never take anything for granted about our national highway infrastructure.
