Broken belt
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Bullseye62, Feb 27, 2013.
Page 1 of 3
does it run the water pump?
You can't put a belt on by yourself?!
Yes it runs the water pump.
I haven't tried. I talked to the dealer and they told me I had to take the fan and some other parts off to put the belt on.
If you run it without a waterpump, you don't cool the engine. You don't cool the engine, you overheat it. You overheat it, you warp a head or cause a head gasket to go out.
So no, I would NOT recommend driving the truck into the shop unless it's across the parking lot. -
I thought that. How hard is it to put the new belt on a C-15?
Shouldn't be that hard. But i run a detroit.
I don't know about the acerts, but it's extremely easy on my 6nz and you don't need to remove the fan...
I replaced both of mine without removing the fan, '05 Acert.
Page 1 of 3
