broken snap ring in oil
Discussion in 'Trucks [ Eighteen Wheelers ]' started by noguns3, Mar 22, 2013.
  1. noguns3
    noguns3 Light Load Member
    52
    13
    Jan 7, 2007
    Minnetonka, MN
    Drained oil for oil change, and found small snap ring broken off in oil. I believe it is from valve seat or jake brake. Series 60 with 570000 on rebuild. Runs great, sometimes hard to start in cold and smokes like hell when cold started. Not much smoke when plugged in. Any ideas?
  3. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Do you have a picture of it? I think the Jake housings have snap rings.
  4. noguns3
    52
    13
    Jan 7, 2007
    Minnetonka, MN
    Mechanic looked at jakes and valve seats. All normal. Went to Detroit Diesel and they said could be wrist pin snap ring from piston or as simple as air compressor snap ring. Looks like I may be looking at new rings and liners if its from the piston.
  5. Heavyd
    7,826
    6,276
    Feb 4, 2009
    Wrist pin snap rings are rather large.
  6. king Q
    king Q Road Train Member
    2,880
    3,038
    Jul 26, 2010
    Johannesburg sa
    I have stripped down a gearbox because on a routine service a bearing roller dropped out in to the oil pan.
    An entire engine as well because of what looked like a piece of snap ring also dropped in to the oil drain pan during service.
    On both occasions could not find anything wrong or missing after tear down.
    Can only deduce they were left there some time before.
    Very frustrating and costly and absolutely nothing can be learned from this because when parts drop out you have to find out from where.
    On the other hand I have stripped a head off to do a head gasket that was leaking to find a deep gauge in the liner.
    This was caused by the wrist pin sliding up and down the sleeve.
    No snap ring in site .
    Don't know if it wore away after coming loose or if it was never fitted.
    I suggest taking the piece you found to an expert who rebuilds these motors regularly and see if it can be identified.
    As mentioned a few good photos in the correct section here could help with your UFO (Unidentified flipping Object).
  7. MJ1657
    MJ1657 Road Train Member
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    I used to be a service manager at a new car dealer. We have found things in oil pans that were "left overs".
    We brought a fairly new vehicle in for a routine oil change, pulled the plug and the oil was barely coming out. We figured out it was a rod cap nut. Pulled the pan down and determined it was an extra from the factory.
    Had a similar deal in a rear end of a pickup.
  8. noguns3
    52
    13
    Jan 7, 2007
    Minnetonka, MN
    Posted pic in previous reply. Thanks.
  9. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    No pic coming thru.
