Bulk tankers
Discussion in 'Experienced Truckers' Advice' started by double_r, Oct 10, 2010.
  1. double_r
    double_r Heavy Load Member
    772
    503
    Sep 6, 2008
    Pittsburgh,PA
    Tell me about hauling them. Would be food products.
  3. 2fuzy
    2fuzy Road Train Member
    1,053
    324
    Jun 19, 2008
    Granite Canon,WY
    I prefer to pull a tank over anything else but liquid in a tank with no baffles has its drawbacks
    but still way better than dragging a van around
  4. double_r
    772
    503
    Sep 6, 2008
    Pittsburgh,PA
    Thank you for your input. This will be a job running bulk flour from rail to plant. First time that I will pull a tanker. They are running my app and I have already talked to the TM. Wish me luck, never pulled a tank although I do have the endorsment, it will be new to me. If all goes right, I am strongly thinking about taking it.
  5. dibstr
    dibstr Road Train Member
    1,308
    932
    Sep 10, 2010
    I assume since you will be loading flour you mean a dry bulk tank? I pulled a dry bulk tank for over 15 years before I came to the Community college. I usually loaded plastic pellets the last few years with a self loading vacuum tank. They aren't really a tank (Although it's called a tank), so no tank endorsement is needed. Generally they pull well, although they can be loaded top heavy depending on the density of the product. Load shift is usually not a problem. If I ever leave the college and go back to driving, that's what I would go back to.
    Best regards
  6. 2fuzy
    1,053
    324
    Jun 19, 2008
    Granite Canon,WY
    sounds like it could be a great gig if you have to deal with a RR company they can be a pita with there rules
  7. kdryan
    kdryan A Pleasant Fellow
    306
    115
    Nov 22, 2005
    Indiana
    Used to haul powdered limestone in central Florida. The stuff would clog up in a heartbeat if you didn't watch the pressure while unloading. God what a mess that place was all the time...
  8. double_r
    772
    503
    Sep 6, 2008
    Pittsburgh,PA
    Ya, got to deal with the rail people. Never dealt with rail but I'm sure they not as bad as some of the food manufactors that I pick up at now with thier rules.
    I am talking to two companies about tankers right now, one pulling the flour and the other pulling sand to the gas wells in this area(big operations around here right now). Both load at the rail and both are less then 10 miles from my house.
  9. rebound
    rebound Light Load Member
    66
    23
    Oct 2, 2010
    new orleans
    Second the glog-ups. Flour is moisture sensitive. I hope you've had some training on how to operate the blower and valves. You need to know your air pressure.
    PLUS be #### careful the pressure is released before you unhook the hose. That is dangerous.
    There is a quiet a bit to know about dry bulk. Its tricky.
  10. double_r
    772
    503
    Sep 6, 2008
    Pittsburgh,PA
    Company provides full training. Thank you for the advice.
  11. rebound
    66
    23
    Oct 2, 2010
    new orleans
    No problem. I used to haul sugar in those things and they could be a pita if you got a bad load. Most of what determines how easy or difficult they are to unload is the receiver and how they are set up. It can get tough when you have to blow it through 500 ft of tubing.
    They are petty nice easy to pull though. I hated having to walk up on top of them. wow no likey the heights
