Bull Gear
Discussion in 'Freightliner Forum' started by Jerryfrancis, Mar 5, 2013.
  1. Jerryfrancis
    Jerryfrancis Bobtail Member
    10
    Jan 29, 2013
    Durham region Ontario
    I have a Series 60 and I have fixed almost everything on this truck except the Bull Gear, I have a engine vibration that obviously is causing it to shake. only does this when im driving it not when im idling, anything else that I should look at?
    I just did the injectors, the head and the ECM
  3. pawpaw1
    pawpaw1 Medium Load Member
    396
    145
    Sep 9, 2011
    Dallas,Ga.
    Hummm . Harmonic Balancer ? Carrier Bearing ? U-joint ? I'd Guess carrier bearing , or u-joint. Start around 60 ? U-joint ,almost certainly . At most any speed , maybe hear a clanging sound , or other unusual noise ? Carrier Bearing. Loose wheels ,maybe , but doubtful.
    If your sure its the engine , how many miles on it ? Harmonic Balancer needs to be replaced by 500,000 miles , for sure.
    Jerryfrancis Thanks this.
  4. Jerryfrancis
    10
    Jan 29, 2013
    The truck has 3 million km, motor was rebuilt at 2 million km.
  5. TruckingSurveyor
    TruckingSurveyor Light Load Member
    133
    43
    Jan 28, 2013
    Oregon
    PawPaw1 has some good comments, if it happens at a certain road speed regardless of RPM or gear, likely behind the transmission, u-joints, carrier bearing, axles, wheels, etc., if it is strictly RPM related then likely in the engine and if that is the case the harmonic balancer is a good guess.
    TS
  6. losttrucker
    losttrucker Road Train Member
    1,436
    1,041
    Mar 9, 2008
    greenville,nc
    Yea I had a "mysterious" unknown, couldnt find vibration ordeal for a week. Monday morning leaving the yard the u-joint broke and left the drive shaft lying in the road.
    First time in 5 years I ever had to ride a hook.......
  7. Jerryfrancis
    10
    Jan 29, 2013
    looks like i may be having to fix the harmonic balancer and bull gear, everything else that was mentioned has been fixed and looked at , unless it may be something else, ....................Thanks for the reply everyone, every suggestions helps
  8. jbourque
    jbourque Heavy Load Member
    924
    553
    Oct 25, 2012
    south english iowa
    a bull gear is tough to change. 1 case bud lite, better part of a afternoon, b/s time with old friends good day.
  9. rebel127
    rebel127 Light Load Member
    296
    149
    Feb 28, 2011
    monroe ct
    The clutch can also cause rpm related vibrations.
  10. TIGERSHARK3060
    TIGERSHARK3060 Bobtail Member
    Mar 6, 2013
    If the bull gear has 1 mil miles on it. Replace it period. If the bull gear fails. You will be doing a whole inframe on the engine which at 1 million miles I would do anyway.
  11. rebel127
    296
    149
    Feb 28, 2011
    monroe ct
    Very true!!!
