Bunk A/C always on low???
Discussion in 'Trucks [ Eighteen Wheelers ]' started by brenes-built, Aug 27, 2011.
  1. brenes-built
    brenes-built Light Load Member
    157
    15
    Apr 14, 2011
    Vancouver, Wa
    My a/c in the bunk blows but very little.. It seems to be on low all the time even if the bunk control is on four.. Its a 99 pete 379, I replaced the fan and motor last winter..any help I would appreciate it....:biggrin_2552:
  3. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    Could be power supply isn't cutting it...maybe upgrade the source wire...less resistance.
  4. brenes-built
    157
    15
    Apr 14, 2011
    Vancouver, Wa
    So you mean, it needs a bigger power wire?? Just try to find a hot wire and add it to the existing one...
  5. Diesel Dave
    9,627
    32,467
    Jan 20, 2010
    Hesperia, Ca.
    Replace the SWITCH !!! I replace my fan motor and it did the same but after I replace the switch, IT WORK !!! I need blanket's now....:biggrin_2559:
    brenes-built, puncher and otherhalftw Thank this.
  6. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    If it's anything like the front blower motor, there's a resistor block that works in conjunction with the fan switch. When they burn up, the fan only works on low on all settings. If it only works on the low setting and turns off on the other speeds, it's the switch.
  7. Diesel Dave
    9,627
    32,467
    Jan 20, 2010
    Hesperia, Ca.
    Thats what i did, replace that block as well.
    brenes-built Thanks this.
  8. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    First thing I'd do is to swap the high speed fan relay and see if that works.
  9. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    I had a Freightliner that did the opposite when the resistor went bad, had NO low speeds but would work on High, guess it depends on how they are wired.
  10. puncher
    puncher Medium Load Member
    540
    358
    Feb 12, 2010
    Tn.
    What he said. You should also be able to pull the switch and remove the incoming and outgoing wires and hold them together and should run on high, confirming the bad switch.
    Diesel Dave Thanks this.
  11. brenes-built
    157
    15
    Apr 14, 2011
    Vancouver, Wa
    I finally got to replacing the switch for the fan speed and no luck.. Where would the resistor switch be located..
