bunk a/c freightliner 07
Discussion in 'Freightliner Forum' started by truck6677, Aug 26, 2014.
  1. truck6677
    truck6677 Light Load Member
    83
    11
    Jul 21, 2012
    Hey my bunk a/c blow hot then cool.is there a expansion vale for the bunk.also on my wiring harness there is as thermal stat.one the harness.anyone know where it goes
  3. xsetra
    xsetra Road Train Member
    5,195
    7,146
    Aug 21, 2011
    My 99 freight. The thermal harness is to regulate the coolant going to the heater has nothing to do with A/C.
    You might be getting low on Freon.
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Cut off heater valves at eng. CK. for bubbles passing thru window on dryer add 1 can freon if you see them and stop adding when none are seen.
  5. walterjacobo15
    walterjacobo15 Light Load Member
    104
    91
    Aug 23, 2014
    Here and there
    Thermostat or Temp sensor? I've seen a temp sensor and it goes in a small hole on the housing, accessible from outside.
