Bunk ac problems
Discussion in 'Ask An Owner Operator' started by John101*, Feb 6, 2024.
  1. John101*
    John101* Bobtail Member
    4
    4
    May 23, 2023
    I have a 2014 cascadia with 849510 miles. My bunk ac works fine when truck is NOT idling but when I turn my truck on it stops blowing air. The controls still work but no air blows at the back. It has all 8 new batteries. Filters are clean checked fuses under hood also good. Does anyone know what it could be? I have a park smart system.
  3. Magoo1968
    Magoo1968 Road Train Member
    2,056
    5,477
    Mar 18, 2021
    St Malo mb
    Mine had two fuses for the bunk fan . One for Parksmart and one for the truck .. I can’t remember if it was behind glovebox or under bunk..
    Bean Jr. and Flat Earth Trucker Thank this.
  4. John101*
    4
    4
    May 23, 2023
    I'll take a look for that thanks!
  5. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    Are the systems even designed to run when the truck runs?
    Don't they have in cab systems tied in to the truck too?
    The bunk heaters I had always shut down when the truck was turned on. Webasto and what not.
    The sleeper vents however. Ran off the truck. Ac and heat.
  6. John101*
    4
    4
    May 23, 2023
    When my truck is running the bunk runs off the truck system. When I turn off the truck i turn on the bunk system. My problem. Is when truck is on the bunk vents don't blow any air. It only works when bunk system is on.
  7. John101*
    4
    4
    May 23, 2023
    Hey brotha I finally got to look for those fuses and it was loose..‍♂️‍♂️ thanks man I really appreciate it!
    Magoo1968 Thanks this.
  8. Magoo1968
    2,056
    5,477
    Mar 18, 2021
    St Malo mb
    Glad it worked out
  9. sbaumann14
    sbaumann14 Road Train Member
    1,236
    1,431
    Sep 1, 2010
    Rhinelander, WI
    A mini split run off a generator. There’s a company named Pinnelas Power that makes kits to put a 6 gal boat tank on ur truck to feed ur generator.
