Bunk Heater Questions
Discussion in 'US Xpress' started by musicgal, Oct 19, 2011.
  1. musicgal
    musicgal Road Train Member
    1,171
    467
    Mar 8, 2010
    Carthage, Missouri
    My bunk heater has the Digi Control box, which is only illustrated in the manual which no instructions on how to make it work......does anyone else have this one?????
    I hit the heat wave button, the green light comes on, the heater comes on for a little while....but that's it.
    The are two little boxes with triangles in them but they only show different temps and I'm guessing one is the temp in the truck since it has gone from 78 to 73.....the lower temp is 68...what does that mean??
  3. highwayman
    highwayman Medium Load Member
    It's like a thermostat, it will not run constant. Set the temp to the lowest you want to the highest you want. It will run until it gets to the high temp you set and then shut off, when the temp in your truck gets below the low temp you set, it will then kick back on warming
    Your cab until it reaches the high temp you have it set.. Etc. And that's how it works... Your truck does not run while this is on, just turn your key to the left on acc ....10-4?
  4. HD_Renegade
    HD_Renegade Road Train Member
    1,470
    607
    Dec 20, 2010
    North Carolina
    Thank you I was wondering that too!!!!
  5. musicgal
    1,171
    467
    Mar 8, 2010
    Carthage, Missouri
    THANK YOU, Highwayman......manual says "Turn truck off"......nothing about the ACC........Fortunately this truck is so well insulated that even at 47 degrees last night it was still very comfortable in here with the truck turned completely off.
  6. NoCoCraig
    NoCoCraig Road Train Member
    2,604
    1,695
    Nov 7, 2010
    Chattanooga, Tennessee
    You do not need to turn the key to ACC. Off works
  7. highwayman
    really, my bad ...on the old bunk heaters acc had to be on to work...thats how it was on my 2011 peterbuilt ....sorry if i misled anyone....but...are you sure? lol
  8. NoCoCraig
    2,604
    1,695
    Nov 7, 2010
    Not on a 2010 Casccadia or a 2012 Cascadia. That is what my experience is.
  9. musicgal
    1,171
    467
    Mar 8, 2010
    Carthage, Missouri
    I ran it for a little while tis morning while sitting, with the truck turned completely off, and it worked fine.....got hot in here really quick....LOL
  10. NoCoCraig
    2,604
    1,695
    Nov 7, 2010
    Yeah, we put up the window shades and open the curtain when we use the bunk heater. That give it twice the cubic footage to heat and makes it easier to maintain a steady temp. Otherwise we get too hot
  11. HD_Renegade
    1,470
    607
    Dec 20, 2010
    North Carolina
    Hey I have the directions/instructions for it here!!!!
