Bypassing idle shut down?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by zaroba, Feb 25, 2017.
  1. zaroba
    zaroba Heavy Load Member
    840
    1,269
    Aug 28, 2012
    South East PA
    OK, my APU quit on me. Pretty sure it's the starter. My bunk heater won't run without the APU running. Thermoking isn't open on the weekends. But there is one located close to my delivery point on Monday morning so will be getting it fixed after delivering.
    It is in the mid 20s in Indiana right now and the truck won't idle unless it is below 20.
    I drive a 2015 Kenworth t680 and need a way to keep it idling.
    It will only idle 5 mins if the tractor brake is set. Bumping the cruise up to 900 rpm won't keep it idling.
    Releasing the tractor brakes will let it idle 15 mins. Wedging the pedal down to put my RPM at 1300 won't stop it from shutting down after 15 mins.
    It's an automatic and even if I put it drive and let it idle it will still shut down after 15 mins.
    I can hit the throttle to keep it idling when it starts to shut down, but this needs to be done every 5 or 15 mins.
    Anybody have any other ideas?
    I'm half tempted to remove the drivers side mirror and cut the wires to the temperature sensor which is sticking out of the casing to see if that works. Can't get to it from under the hood and can't get to it by removing the instrument cluster.
    It's a leased truck, not a company truck, and I do plan to have a word with leasing on Monday about why leasers can't idle since we are paying for the fuel and maintenance.
    And it's a certified clean idle, so those "no idling diesel powered vehicles over 5 tons" laws don't apply to it.
  3. albert l
    albert l Road Train Member
    1,040
    1,505
    Feb 10, 2013
    On the Road
    Get a Motel room ?
    MartinFromBC Thanks this.
  4. Cat sdp
    Cat sdp . .
    21,297
    76,136
    Apr 8, 2012
    Orion's Belt
    Set a brick on the accelerator pedal...
    Maybe you'll get lucky and the temperature will drop ...
    Rubber duck kw Thanks this.
  5. zaroba
    840
    1,269
    Aug 28, 2012
    South East PA
    I'd rather avoid that if possible. I have a stop in a town 10 miles away tomorrow morning (currently at a rest area) and the 2 hotels in the town don't have space for a semi so cab cost would be added to the hotel cost. No truck stops in the town either.
    Tomarrow night I might be able to do that though. Greater distance to the Monday delivery will allow better chance of having a hotel near a truck stop.
  6. Studebaker Hawk
    Studebaker Hawk Road Train Member
    3,018
    9,852
    Oct 18, 2010
    NW Indiana
    It is pretty clear that the ECM program is specifically designed to thwart all of your efforts. The only way at this point is to let a technician with the password change the parameters, which doesn't help you one bit. Good luck.
  7. Shock Therapy
    Shock Therapy Road Train Member
    1,259
    28,017
    Feb 4, 2016
    n.cntrl il
    If it will idle at warmer temps see if you can get a couple of them hand warmer packets and tape em to the sensor.
  8. Studebaker Hawk
    3,018
    9,852
    Oct 18, 2010
    NW Indiana
    Maybe if you dunk the temp sensor in a 32 oz container of ice water it will fool it...
    rabbiporkchop and Shock Therapy Thank this.
  9. milehunter43
    milehunter43 Heavy Load Member
    732
    811
    Aug 23, 2015
    Either of these two things, or ziptie a heating pad to the sensor.
  10. zaroba
    840
    1,269
    Aug 28, 2012
    South East PA
    Hmm...can the ecm be disabled via pulling a fuse without negative side effects to the engine while idling or will it just not run at all?
    (May seem like a dumb question, but that knowledge is beyond my engine expertise)
  11. Studebaker Hawk
    3,018
    9,852
    Oct 18, 2010
    NW Indiana
    I would not mess with the fundamentals of the tractor. If needed call the 24 hour service line. If it is a Penske or Ryder truck they should take care of the APU problem. One of their techs would be able to change the ECM to accommodate the situation if they can't repair the APU.
