C13 iva question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by QUALITYTRUCK, Apr 23, 2015.
  1. QUALITYTRUCK
    1,817
    1,783
    Jun 14, 2009
    romulus,mi
    Have low IVA oil pressure under a engine load.Have narrowed it down to not being pressure sensor,control valve or check valve.What is the best way to test for oil leaks on all 3 actuator housings?Have already tried cranking engine with ECM fuse pulled and control valve unplugged while looking for leaks,but it only happens while engine rpm is above 1500 and warm.Thanks in advance.
  3. PaulE
    PaulE Medium Load Member
    413
    145
    Jan 15, 2009
    Verona Wi
    I had same problem with a C 15. turned out that one solenoid was a little loose. it 'rocked' slightly when grabbed with thumb and fore finger. tightened studs...end of problem. hope this helps
    QUALITYTRUCK Thanks this.
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    I've seen some cracked housings. Many times when the housing cracks, the solenoid screws come loose and I've seen some broken. When they crack, it's typically right by the solenoids. If the housing is cracked, make sure the rocker studs are torqued to spec before you put the new housing on. Loose rocker studs can also allow oil to leak by the rocker studs and reduce oil pressure up there. Cracking is more of an issue on C15's, but I'd sill check them really close.
    Does engine oil pressure drop when the light comes on? Low oil pressure could kick that code as well.
    You can run it with the valve covers off and look for oil squirting out where it's not supposed to. Check really close at the oil bridges that go from the head to the IVA housings. Nothing but a few O-rings in there to change if they're leaking. I've seen them cracked as well, usually from improper installation.
  5. QUALITYTRUCK
    1,817
    1,783
    Jun 14, 2009
    romulus,mi
    You hit it GrapeApe! Oil bridge to head O-rings were flat. Was not able to see them leaking, but changed them as precaution since I had actuators off anyway. Thanks to all that helped.
