C15 acert inframe
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by rydr, Dec 1, 2019.
  1. rydr
    rydr Light Load Member
    123
    92
    Jan 8, 2019
    Currently having my sdp c15 rebuilt. doing 16:1 ipd low compression kit. head is going to machine shop monday. what studs or bolts do i need on the top end? ive heard of acert engines having issues with breaking studs and bolts in the head. i dont want to put it back together just to have stud issues in the future. what are the part numbers needed for the updated parts. also needing to get a good ecm tune if anyone can point me in the right direction. thanks
  3. Shawn2130
    Shawn2130 Heavy Load Member
    896
    1,897
    Sep 20, 2015
    Southern Ontario
    I’m here to learn as well...
  4. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    What is your full S/N? SDP21692 and up have the improved VVA studs. I would replace all head bolts. If you can find a place to do it, cryogenic treated head bolts have shown to hold up better. Close inspection of block is a must especially where liners seat. If in doubt, have counterbore cut. Don't get crazy with setting liners @ top end of spec. Copy and pasted from Cat on a 3406 HG. Although the 6I3066 Cylinder Head Gasket is designed to seal the head to block joint throughout the allowable liner projection range, the optimum projection for the maximum sealability of both exhaust gas and fluids is 0.090 mm (.0035 in).
    dustinbrock, SAR, pushbroom and 4 others Thank this.
  5. rydr
    123
    92
    Jan 8, 2019
    full engine s/n is SDP07312. intake side of the head and my cac is completely covered in soot, should i get the cac cleaned at a radiator shop. also going to need a new air compressor can i use the 6nz style air compressor?
  6. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Description of Change: An improved stud is used on the engines that are listed above. The new stud has an "elliptical fillet" underhead with "J" threads. The new stud has increased durability.
    Adaptable To: The 304-9553 Stud is a direct replacement for the 233-3672 Stud and the 288-4109 Special Stud. The improved stud is adaptable back to the first production of the listed engines. The change is effective at the factory with the engine serial numbers SDP21692-UP and NXS32162-UP.
    SAR, Oxbow, pushbroom and 3 others Thank this.
  7. Cat sdp
    Cat sdp . .
    21,279
    76,003
    Apr 8, 2012
    Orion's Belt
    How many miles/hours did you get out of it....?
    Oxbow Thanks this.
  8. rydr
    123
    92
    Jan 8, 2019
    750k. im only taking it apart to convert it to single turbo with the low comp pistons. removing a few other parts aswell
    Oxbow and Cat sdp Thank this.
  9. rydr
    123
    92
    Jan 8, 2019
    when going from 18:1 pistons to 16:1 low comp pistons should I also change the piston cooling nozzle to a cat 279-1152? also would anyone know of the part number for the big plug where the cgi cooler runs to the block?
  10. DieselTech_Aus
    DieselTech_Aus Light Load Member
    274
    309
    Dec 20, 2017
    WA
    stan
    original cooling jet is fine.
    standard rocker shaft studs are fine, just torque to spec.
    if you get the ECM tuned just get them to delete IVA, sharpen up response and adjust the need for boost before rack increase. don't stretch the pulse width and add lots of fuel. ideally it would be best to run a 6nz 70pin ECM and harness, fit 6nz cam sensor, boost sensor and a 988H/24M interal harness and re-pin to suit
    the 6nz compressor does fit. but you need the 6nz tru-flow750 gear and adapter plate to fit it. then the relative plumbing alterations.
    what do you mean by CGI cooler?
  11. rydr
    123
    92
    Jan 8, 2019
    CGI is clean gas induction on SDP engines basically cats version of egr. under the exhaust manifold is a decent sized hole where coolant is supplied to the cgi cooler from the block between #2 and #3 cylinders. i kept with SDP style reman air compressor. maybe one day i will do a 6nz conversation
