c15 Acert Question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Alanp613, Dec 19, 2010.
  1. Alanp613
    Alanp613 Road Train Member
    1,475
    801
    Apr 9, 2009
    Haslet,Tx
    Hi guys newbie to the mechanicals of the c15. What is an inframe?? is it the same an overhaul or rebuild?? is there a recommended time to do this or just wait till the engine can't run anymore?? I currently have 805000 miles on mine.
    Also I hear drivers turning up their engines, does that just mean reprogramming the ecm to it's full potential or will mechanical modifications also be required??
    Thanks in advance!!
  3. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,483
    Oct 18, 2009
    Waynesburg, Pa
    Inframe means the engine is rebuilt in the truck. Most can be done this way unless there is a problem with the crank.
    I have a C15 ACERT had the ecm tuned that is the best money you can spend on the truck. Talk to Mr Haney on here and get a PDI stage 1. You wont be disapointed, that and get rid of your stock mufflers if you still have them.
    Alanp613 Thanks this.
  4. e500gvr
    e500gvr Light Load Member
    125
    32
    Aug 21, 2006
    Bloomington,MN
    Cat HD engines guidelines suggest overhauls be considered at any of the following:
    600,000+ miles or
    • 120,000 gallons of fuel or
    • 12,000 hours
  5. Diesel Dave
    9,521
    31,507
    Jan 20, 2010
    Hesperia, Ca.
    That's funny...........I got 1 million before mine was rebuild.
  6. Diesel Dave
    9,521
    31,507
    Jan 20, 2010
    Hesperia, Ca.
    DL550CAT is right ! You can find Mr. Haney on here and he will do wonders to your KITTY. Go on search and write Mr. Haney and you will find his threads.
  7. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,041
    Dec 17, 2008
    The engine will let you know when it's time for a rebuild............if nothing else it will start getting excessive blow by on the crankcase vent tube and fuel mileage will drop.
    With an Acert there is a small amount of mechanical modificationd that can be done to make it run better. The big changes are reprogrammimg the ECM with a different flash file for more power and fuel economy.
  8. Big John
    Big John Road Train Member
    2,022
    1,521
    Oct 7, 2006
    Oklahoma
    Maybe for a C-12 or C-13.
  9. Krooser
    Krooser Road Train Member
    2,493
    1,066
    Jul 25, 2010
    Wisconsin
    CAT sez rods/mains after 10,000 gallons of fuel... 6 MPG=600,000 miles... which is about right IMHO... I did my rods/mains after 714,000 and they were still OK...not perfect but still serviceable.
    My 3406E was done in the 600,000 the first time but I don't know why. It was done before the PO to me bought it. I just redid it at 1,616,000...
  10. 3406E. 1.1 million since overhaul and oil samples are clean.
  11. bigrigbuckmaster
    bigrigbuckmaster Light Load Member
    67
    21
    Mar 28, 2010
    Pittsburgh power does great rebuilds, maybe if you get on their waiting list you could get it overhauled when you hit a million miles. last I heard the shop was booked till mid february.
