C15 High EGTs
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Ccjohn, Oct 22, 2016.
  1. Ccjohn
    Ccjohn Bobtail Member
    49
    9
    Sep 29, 2016
    We've got a 2007 Peterbilt 379 with a C15 ACERT.
    On its last trip the EGTs were up near 1500 on the highway and the warning light was on. Around town it's still 800-1100. We have an identical truck to it and on the highway we never see over 1000 and around town is typically 600-700.
    It's got new fuel filters and it's not indicating a fuel restriction. The air filters are clean and there's no air restriction. I can't hear any boost leaks. It still builds 40psi of boost. There's no excessive smoke.
    Anyone have any thoughts for what's causing the high EGTs? I've read a bad turbo can cause high EGTs but it doesn't feel like it's down on power and it's still building plenty of boost.
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Just a thought, have you double checked the gauge for accuracy? That 1500 seems really high, I haven't had a pyro gauge for years but that's almost catastrophic failure temps.
  4. Ccjohn
    49
    9
    Sep 29, 2016
    I swapped the gauge between the 2 trucks and no change. The driver using the truck said he saw the warning light and slowed way down and the temps dropped to 1100-1200. Luckily he was almost at the destination when the warning light came on. But he couldn't stay at highway speeds and keep the temp down
    I haven't swapped EGT probes however because they are seized in the elbow after the turbo pretty well and I don't want to risk snapping the one on the good truck
  5. gunner76
    gunner76 Medium Load Member
    500
    137
    Mar 11, 2010
    IA
    How about swapping the whole elbow over? At 1500* you'd have some major failures going on.
    tony97905 Thanks this.
  6. AModelCat
    164,482
    Water and oil temps normal?
    tony97905 and wore out Thank this.
  7. tony97905
    tony97905 Road Train Member
    1,023
    12,241
    Feb 28, 2015
    Land of Ahhhhhs
    Verifying the reading is the first order of business, nothing like throwing money at a non-existent problem. Severe exhaust restriction and remember Pete air filters get dirty on the inside and not the outside like most.
    Edit to add - It's not uncommon for the exhaust sleeves to fail at the welded seam and the pieces to take out the high pressure turbo.
  8. tnevin225
    1,166
    1,601
    Jan 1, 2014
    I would say if every thing on the air side checks out problem may be on the fuel side. Could just be dumping to much fuel to the cylinders. Good Luck
  9. bigguns
    bigguns Road Train Member
    2,846
    6,855
    Jun 13, 2013
    Omega,GA
    Plugged radiator and CAC not letting air flow properly?
    Diesel Dave and BoxCarKidd Thank this.
  10. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    $75 inferred heat gun? Good for many other uses.
    Oxbow and AModelCat Thank this.
  11. wore out
    wore out Numbered Classic
    17,285
    214,196
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Hot cast usually puts off a little smell. I used to have a E we played with just above 1000 it would let me know. I would have to know no doubt. She won't live long with that heat. Since he referred to the elbow I can only assume the probe is post turbo
    Oxbow Thanks this.
