Cabin air filter
Discussion in 'Freightliner Forum' started by Philalsp, Jun 8, 2017.
  1. Philalsp
    Philalsp Bobtail Member
    I have an 01 freightliner classic xl and am wondering where the cabin air filter is at. Looked everywhere and can't find it. Also my engine fan stays on after I turn on the a/c and won't go off. Replaced high and low switches. Replaced solenoid. And had system charged. It blows cold. Everything seems to be working fine but the fan won't shut off unless I turn off the ac
  3. spyder7723
    spyder7723 Road Train Member
    15,471
    25,078
    Mar 31, 2013
    sarasota, fl
    The cabin on air filter is on the windshield cowl. You can easily see it if you sit in the passenger seat and lean forward looking out and down.
  4. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
  5. spyder7723
    15,471
    25,078
    Mar 31, 2013
    sarasota, fl
    I just bought an 01 xl. It's right there on the cowl, just under the right side windshield. If i remember ill grab a picture in the morning.
  6. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    my o5 don't have one there is a aftermarket one that can be slapped on the cowl yes
  7. snowwy
    snowwy Road Train Member
    20,611
    13,326
    Jul 6, 2009
    The low switch is designed to shut the compressor off if pressure gets low. Shouldn't have anything to do with fan.
    Have you looked to see if there's 2 high pressure switches? 1 would be for fan. Other for compressor if pressure gets high.
    Possible relays or wiring issue would be other causes. Along with possible overcharged Freon
  8. nightgunner
    nightgunner Road Train Member
    2,112
    2,800
    Jul 23, 2013
    Cedar Rapids, IA
    I have an '02 with the outside filter, if you '01 doesn't have it check here:
    Open the hood, look on the passenger side firewall. You should see two silver "clips" remove them and a cover should open to slide out the filter.
    FYI: Freightliner in all their infinite wisdom did not have a filter as a standard item. If you have an ex big fleet truck, it may have been ordered without one.
