Cage a brake
Discussion in 'Experienced Truckers' Advice' started by bandit74, Jul 15, 2015.
  1. bandit74
    bandit74 Light Load Member
    148
    92
    Jul 4, 2015
    One night I blew an airline on my trailer. I was able to double the line and tape her up, stopping the leak. One brake was locked down tight, a mechanic came out and caged the brake. Since then, I carry a 3/4 inch wrench and a couple of caging bolts.
  3. tucker
    tucker Road Train Member
    12,647
    40,425
    Jun 13, 2008
    IN
    And if a drunk driver lighting his meth pipe while giving oral sex to a billy goat ,while texting and playing xbox and smoking a Camel light too... Runs into you, his lawyer will see to it that you are at fault and pay
  4. Cottonmouth85
    Cottonmouth85 Bad Influence
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    You can also back off the slack adjuster.
  5. jbatmick
    jbatmick Road Train Member
    2,200
    2,510
    Dec 1, 2009
    hastings, Fl
    Most new cannisters come with a caging bolt attached on the side.
    OLDSKOOLERnWV and G.Anthony Thank this.
  6. TripleSix
    133,259
    Next time, instead of double wrapping an airline that you're going to toss, put a dime in where it screws together and tighten it down. Then capture the spring. The compression on the dime will stop air from escaping.
  7. 25(2)+2
    18,759
    45,974
    Sep 18, 2006
    the road less travelled
    You can't always back off the slack adjuster. Too much pressure is applied by the spring. All caging does is take the spring brake off mechanically in place of having air pressure to release it. If the brake chamber can be activated with air pressure, the service brake will still work. Backing off the slack totally defeats that brake.
    I wouldn't make a habit of driving with a brake caged. But it may get you to a safer place or off the roadway while waiting for a proper repair.
    HeWhoMustNotBeNamed and 91B20H8 Thank this.
  8. marineman227
    marineman227 Dock Waterer
    600
    796
    Jan 26, 2008
    Neenah, WI
    My company won't reimburse me for dimes left in air lines, I use bubble gum like a real McGyver
    runningfr8, tucker, Big Don and 2 others Thank this.
  9. marineman227
    600
    796
    Jan 26, 2008
    Neenah, WI
    I've actually never broken an air line to the chamber, I have had a few diaphragms go though. Can you use the old bic pen trick on those lines? I have a few in my truck just for temp fixes on air lines.
  10. xsetra
    xsetra Road Train Member
    5,196
    7,146
    Aug 21, 2011
    I was told by a DOT in Wyoming, during an inspection, truck trailer combination is allowed to have one braking position inoperable. That is less than 20% of braking capacity.
    He told me I had one brake to far out of adjustment and he gave me a CVSA sticker.
    Right or wrong I don't know.
    25(2)+2 Thanks this.
  11. 201
    201 Road Train Member
    12,769
    26,262
    Apr 16, 2014
    high plains colorado
    Can you even cage a new brake chamber? I've been out of the loop for a while, but I seem to remember, new brake chambers had that hole where the caging tool goes, filled in. Years ago, I always kept a caging tool in my tool box. And I've heard that too, you can have 1 brake inoperative. I'm surprised they still allow that.
