Calcium carbonite
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by PJM41, Jun 25, 2021.
  1. PJM41
    PJM41 Bobtail Member
    20
    Oct 26, 2018
    Has anyone hauled processed calcium carbonate or even basic powdered lime? Does it stick to or stain your trailer like cement does, and does it make as much of a mess when loading? Is it all loaded through the center hatch or do all 3 hatches get used and how long does loading/unloading take?
    I currently haul cement powder and am pursing a calcium carbonate contract. Thanks for sharing your experiences
    NavigatorWife Thanks this.
  3. PJM41
    20
    Oct 26, 2018
    How do the rates compare to cement?
  4. Long FLD
    Long FLD Road Train Member
    12,845
    53,750
    Mar 4, 2015
    When I pulled pneumatic we hauled a lot of calcium. One place loaded it all thru the back hole and one place loaded it all thru the front hole. We got washed out and rinsed off after every load because of our reload and the trailers had Alumaclear on them so I can’t speak to staining or not. It unloads real easy, flows like water. If you have any bad seals anywhere you will find them.
  5. PJM41
    20
    Oct 26, 2018
    I also have AlumaClear and that helps a ton with the staining. The cement, however, will still harden to the surface if not constantly kept clean. Did the calcium rinse off easy or did it harden over time?Did the shippers make as much as a mess when loading as they do at cement mills?
  6. Long FLD
    12,845
    53,750
    Mar 4, 2015
    We only loaded at 2 places and they were decent. After we unloaded we went and got washed out and washed because our reload was food grade so I don’t know if it gets hard or not.
  7. Suspect Zero
    Suspect Zero Road Train Member
    2,530
    9,733
    Oct 10, 2016
    Brookfield, IL
    I ran calcium when I first started, but we trans-loaded out of rail cars, so can't speak to any build up on the trailer from top loading. Our trailers for that were dedicated to that product, so they didn't get washed often, basically when it rained. I never noticed a great deal of staining on them but I would say they became dull and flat looking over time. They were not AlumaCleared.
    But it did unload easy, as @Long FLD said.
  8. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    We haul some high calcium hydrated lime and yes it does stain/burn unprotected aluminum and will build up. The one drive we have that does it dosent take very good care of the trailers and it shows.
  9. RockinChair
    RockinChair Road Train Member
    5,353
    14,280
    Feb 19, 2012
    Lubbock, TX & thereabouts
    I don't know about calcium carbonate, but when hauling lime they always loaded us through the dome lid on top of the #3 pod. We pulled 1600cf 4-pod trailers.
    If the lime is hydrate, you will have to pressure it down using top air toward the end of the loading process. Once your trailer is full, they'll remove the spout and you'll close the dome lid. Fire up the blower, open your top air valve, close the blowdown, and pressure the tank up to 15 PSI. Once you get to 15, stop the blower then open the blowdown. After the tank pressure gets to zero, open the dome lid so they can finish loading you. The hydrate will have been packed down a foot or two.
    Lime does pay a higher rate than cement. Unloading time is about an hour - unless you have to unload pebble lime into a silo. In that case, I hope you have a metal hose and a lot of patience.
