Cam lobe flaking
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Skiharleydoo, Jun 12, 2017.
  1. Skiharleydoo
    Skiharleydoo Bobtail Member
    11
    4
    Jun 12, 2017
    Rockies
    I had the valve adjustment done and was told #4 lobe is flaking. ISX15, 600 HP. (2013). What are the consequences if I put this off ?
    dca Thanks this.
  3. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    Your engine will develop a miss from the cam lobe being flat and you'll have metal flakes circulating through your oil, which eventually will wipe out your motor.
    dca and HalpinUout Thank this.
  4. Tug Toy
    Tug Toy Road Train Member
    7,049
    73,802
    Jul 4, 2015
    Corn field
    IMG_1709.JPG IMG_1710.JPG IMG_2043.JPG It will lead to this.
    Once mine was found I drove it for about 25k miles before I did this. I may have gone a year but be preparing to have it stop running on you at the worst moment. The engine will probly be destroyed when it goes. That means no core credit $8k on top of the new $20 to $40k motor. Mine was not really flaking but definitely a bad cam and follower
    tucker, dca, boneebone and 1 other person Thank this.
  5. HalpinUout
    HalpinUout Road Train Member
    7,074
    18,165
    Oct 2, 2011
    How many miles are on it?
  6. Tug Toy
    7,049
    73,802
    Jul 4, 2015
    Corn field
    Also I think it matters if it is an intake or exhaust lobe. Intake lobe is not as critical as the exhaust because if it can't get air in don't worry about getting it out.
    If you can get air in but can't get it out it will lead to catastrophic failure.
  7. HalpinUout
    7,074
    18,165
    Oct 2, 2011
    How many miles did it have on it when you took those pictures?
  8. Tug Toy
    7,049
    73,802
    Jul 4, 2015
    Corn field
    807k miles. New engine at 834k. It still ran pretty good whe I pulled it in the shop to replace and 7mpg. It was an exhaust lobe #5. Everything else looked good except a oil leak from the front cover in the cam area.
    HalpinUout Thanks this.
  9. Skiharleydoo
    11
    4
    Jun 12, 2017
    Rockies
    367k
  10. HalpinUout
    7,074
    18,165
    Oct 2, 2011
    What is the exact cause of this?
  11. Ezrider_48501
    3,845
    5,133
    Apr 2, 2011
    bismarck, nd
    normally once a cam starts to go they go pretty fast. once the hard facing gets worn and it starts eating up its roller its going to eat itself alive pretty quick.
    Grubby and BoxCarKidd Thank this.
