Can someone explain this for me?
Discussion in 'Intermodal Trucking Forum' started by JReding, Aug 24, 2017.
  1. JReding
    JReding Road Train Member
    1,957
    3,510
    Sep 8, 2014
    Puyallup, WA
    A friend posted this today, I've never seen it before. Has anyone dealt with this, and what is it?
  3. Steel Dragon
    Steel Dragon Road Train Member
    2,681
    2,833
    Nov 23, 2015
    Port for extra set of axles.
    BUMBACLADWAR and JReding Thank this.
  4. JReding
    1,957
    3,510
    Sep 8, 2014
    Puyallup, WA
    Really, or are you yanking my chain?
    How's that work?
  5. Canned Spam
    Canned Spam Road Train Member
    1,504
    2,906
    Mar 8, 2010
    STL
    I hauled containers for a few years and I've never seen one like that. I'm kinda curious myself ha
    JReding Thanks this.
  6. Steel Dragon
    2,681
    2,833
    Nov 23, 2015
    I'm guessing but you've never seen a ten axle truck?
    I doubt all the axles are run through one set of lines..but I could be wrong.
  7. Riprap
    Riprap Light Load Member
    286
    1,979
    May 31, 2014
    Saginaw, MI
    The extra glad hand is used to release the suspension pins on stretch frame chassis. It makes a chassis frame capable of loading a 20,40 or 45ft container.
    You disconnect your red line from tractor, put it onto the extra glad hand, apply air then pins release. Stretch or compress the chassis to correct length, then remove the gladhand and pins pop back into place. Rehook your glad hand to the normal red one, add air and away you go.
    ChicagoJohn, Sublime, speedyk and 12 others Thank this.
  8. Foots
    Foots Bobtail Member
    28
    17
    Jul 22, 2014
    We have a CN tri-axle like that in Marion. It can go from 40' to 53'.
  9. RERM
    RERM Road Train Member
    1,683
    1,125
    Dec 13, 2012
    Chicago, IL
    That's how our 20'-40' chassis work.....
  10. noluck
    noluck Road Train Member
    1,616
    11,683
    Jun 10, 2011
    greenville,sc
    You're wrong. One set runs them all. Just plug and play at the back where you pin them on.
  11. MACK E-6
    49,997
    237,997
    Is that just for intermodal trailers? I've pulled stretch flats that weren't set up this way.
