Capacitance Coupling via Magnetic Antenna Mount
Discussion in 'CB Radio Forum' started by BTShepp, Feb 3, 2017.
  1. BTShepp
    BTShepp Blue Demon
    373
    215
    Oct 31, 2015
    Chicago, IL
    A lot of operators--CB and ham alike-- have mixed, if not negative, opinions towards the quality of ground that a magnetic mobile antenna allows for. It's understood mathematically that the higher the frequency, the more efficient the coupling is, making the antenna a great, or at least decent, choice for VHF and UHF applications. Larger bases provide more surface area for a better capacitance coupling to the vehicle in addition to a stronger physical bond to the vehicle, keeping the whip in place.
    But down here in the 11 meter band, is the capacitance coupling enough to make the magnetic antenna reasonably efficient, for lack of a better term? Is it inferior, superior, or comparable to a "hard" ground, all else equal?
    Below is an interesting article in support of magnetic antenna systems; indeed, it is one of the few in support of magnet antennas.
    http://www.cosjwt.com/index.php?a=3
  3. Ridgeline
    22,718
    123,148
    I brought up the question and no one seemed to get it.
    With a magnetic mount antenna, a lot of issues go away, why do they work better than some of the mounted setups on vehicles?
    BTShepp Thanks this.
  4. Meteorgray
    Meteorgray Heavy Load Member
    754
    597
    Jan 1, 2016
    The only antennas I use have magnetic bases, from the 3-foot K30 on the trunk of my Mazda to the 5-foot Wilson 1000 on the roof of my F250.
    I like the magnetic design because of the enormous versatility of being able to place the antenna where it is the most advantageous and being able to remove it when not needed.
    On my car, I get the best SWRs with the antenna on the center of the roof, but I can't drive it into my garage with it there, so it goes on the lid of the trunk, where it fits into the garage just fine. The compromise is that my SWR is at 1.1 on the roof and at 1.5 on the trunk. Big deal. Plus, I often remove the antenna and put it in the trunk because it's not needed until I'm on the open road anyway.
    For my needs, the magnetic mount works very well. I get good SWRs and a range that is quite satisfactory.
  5. BTShepp
    BTShepp Blue Demon
    373
    215
    Oct 31, 2015
    Chicago, IL
    Good point. It's hard to get a fair comparison all of the time, though. Most magnet mounts are placed on metal car roofs with all perpendicular and no parallel metal relative to the antenna. Many hard installs are done poorly-- short antennas, bad placement on vehicle, little to no ground, etc.
  6. BTShepp
    BTShepp Blue Demon
    373
    215
    Oct 31, 2015
    Chicago, IL
    I used to think magnetic antennas were inferior and marketed for their convenience over functionality. I'm learning that they really give hard installs a run for their money, possibly exceeding many "permanent" mobile set ups.
  7. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    Magnet mount on roof could outperform 9 foot whip on trunk lid.
  8. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Ill offer my 2 canadian cents worth when my sirio mag ant gets picked up in a week and a bit..
    Ill have a stryker hpc2 and sirio mag mount on my hemi hopefully by then..
    Mark is shippin it out fri..
    Dont know how i keep finding myself in this darn loop....
    I had about 6 different radios and got down to two..Now in back to 6 again..
    My 1st cobra 29 from late 90's
    A cobra chrome with midnight 250 linear
    My 1st stryker 955
    My 2nd stryker 955
    And my newest stryker 447hpc2..
    Gonna have to sell the chrome,midnight 250 and a tx star high drive 350...
  9. CETjourneyman
    CETjourneyman Bobtail Member
    Sep 18, 2017
    Very simple. Because with a mag mount at 11 meters, your looking at a 5 ft whip and the other 4ft is coiled up as an inductor between the whip and magnet. The inductor equalizes the impeadance to 50 ohms with or without a proper ground plane thus giving low reflected power. A standard 9ft 1/4 wave whip (no inductor) must have a matching full size ground plane to acheive 50 ohms. any less than that and you run into an impeadance mismatch/reflected power. Same with 5/8 wave fiberglass antennas but the inductor is top loaded.
    lilillill Thanks this.
