Cargo Weight Estimate
Discussion in 'Flatbed Trucking Forum' started by NWstates, Dec 26, 2014.
  1. NWstates
    NWstates Bobtail Member
    10
    Nov 10, 2013
    On another thread I read there's a website that will help you estimate your load weight; bulldozers, rocks, etc I guess. Anybody know of that? Also, what about those scales you can have on your truck. It sounds like waiting to get to a Cat scale is a bad bet.
  3. beastr123
    beastr123 Road Train Member
    2,947
    24,180
    Jan 2, 2014
    Moose Jaw SK CAN
    good gauges on the air ride combined with good records are a good way to get
    within 500# per gauge.
    be sure that your unit is on level ground (for example 1 steer tire on a 2'" rock
    can change drive axle reading by 1500#)
    my book has a chart from 35# to 85# and room for 6 readings per line
    for drives and trailer.
    on my unit 53# is 34000 on the drives and 58# is 34000 on the trailer
    69# is 37500 on drives and 72# is 37500 on trailer
    ramblingman Thanks this.
  4. Freightlinerbob
    Freightlinerbob Road Train Member
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    A simple air gauge is good enough with a little trial and error. You can get within 500# with some experience but I've found that ambient temperature and humidity can affect the readings so it's not fool proof but unless you're loading within 500# of gross, it's good enough.
    Since I pull a fixed tandem flat, when in doubt, I load heavy on my drives since I can burn off 1000# of fuel and shift any extra onto the steers.
  5. snowwy
    snowwy Road Train Member
    20,611
    13,326
    Jul 6, 2009
    i keep my steers maxed out at 12.4 with full tanks. the truck i drive now, won't slide the 5th wheel any farther back so i'm stuck on this particular truck.
    if you have a air ride gauge on your truck. and i think most do. learn where it reads when your drives are loaded at 34,000.
    if i hit that mark. i roll the truck back and forth a little and use the trailer brakes to park. so i can get a confirmed reading at or under 64 on my gauge. also need level ground.
    if i'm over that 64 mark, the load gets repositioned backwards.
    if you have an exact type of load front to back. centering the load on the trailer is usually the best way to load. whatever your truck gauge reads, the trailer will be the same, give or take 1,000 pounds. trailers will usually have either a turn signal in the middle of the trailer or a marker light so EVERYONE knows where center is. including the forklift operating loading you.
  6. JoeBear
    JoeBear Light Load Member
    103
    46
    Jul 18, 2014
    Houston, Tx
    34k lbs on drives on the psi gauge is right above the line on 50 psi on most trucks if fifth wheel is in middle position or the lockd maybe 50% of time need to know your truck. If mine is on line I scale everytime
  7. kwswan
    kwswan Road Train Member
    2,026
    11,060
    Jul 26, 2009
    mcminnville,tn.
    Ritchiespecs.com is what you are looking for.
    NWstates Thanks this.
  8. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    I just google the model number of what I am hauling to get the weight and I use the operating weight not the shipping weight. I don't know how much fuel is in there most of the time.
  9. kylefitzy
    kylefitzy Road Train Member
    4,752
    19,798
    Aug 12, 2007
    Kansas city,Mo
    Air gauges can be all over the place depending on what suspension and truck. The only truck I have driven with a suspension gauge (1995 t-800 straight truck flatbed with an 8 bag suspension) was 60psi for 34000 and 80 psi for 44,800.
