Cascadia 2016 automatic d12
Discussion in 'Ask An Owner Operator' started by Batman13, Dec 10, 2020.
  1. Batman13
    Batman13 Light Load Member
    110
    45
    May 20, 2020
    Is a cascadia 2016 automatic d12 a good tractor?? Need info..
  3. arn12
    arn12 Bobtail Member
    Very good
  4. Blue Zombie Trucker
    Blue Zombie Trucker Light Load Member
    279
    681
    Nov 1, 2017
    I drove 2 of them when I started at a mega. DD13 w/ DT12. They did well, except that until the tranny oil was warmed up above 85 degrees, they would *not* shift, so, if it's *cold*, prewarm the tranny oil. Also, when backing to a dock, disengage both the hillhold and traction control for much smoother backing. Also, don't confuse the transmission by feathering both the brake and the accelerator; one or the other, not both, for smooth backing.
  5. Brandt
    Brandt Road Train Member
    4,618
    6,346
    Sep 17, 2012
    Watch out on the Freightliners with Detroit Diesel engines. The One Box emissions system seems to go bad around 600,000 miles. The DOC/SCR filers stop working and the only fix is a new emissions box for about $12,000.
    feldsforever Thanks this.
  6. Batman13
    110
    45
    May 20, 2020
    Got you..thankx 4 the info
  7. Batman13
    110
    45
    May 20, 2020
    Blue Zombie Trucker Thanks this.
  8. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    I like it. But running into box trouble at 450k
